Channels 13- 41 are in red on the screen . how can i prograk like 2-13?
Go into menu mode. Find the settings or channel programs menu. There, make sure the air/antenna feature in the menu is selected and then re-program the channel line-up. You must have your outside antenna or rabbit ears connected.
In the menu, find antenna/cable. Locate cable and program from there.
SOURCE: orion tv only has 2 channels and it's hooked up to cable
go to menu,go to were it says cable and air,select cable. then go up to auto program do search, this should do what you want.
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
