Samsung 40" 1080p 120Hz Slim LED Smart TV UN40ES6100F Logo
N
Natalie Munro Posted on Dec 14, 2014
Stop Netflix zooming in so I can't see the picture correctly?
Starts running as normal then picture will zoom so far in I can't see the picture correctly. I have tried changing picture size but nothing I have done so far has helped.
3 Related Answers
A
Anonymous
  • Posted on May 06, 2008
SOURCE: Zoom Function and Verizon Fios TV
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
Anonymous
  • 171 Answers
  • Posted on Sep 25, 2008
SOURCE: Picture too large for screen after 2 months of normal operation
Go control panel. display. Click on the settings tab, click on advanced. Look for thr tab that relates specifically to your video card and looh for the option to activate the scrolling option on your display and turn it off. This should fix your problem
roety
Eric Rotmil
  • 587 Answers
  • Posted on Aug 01, 2009
SOURCE: i have a 52
FCC says it only has to display a picture, with 16 formats it tough to get it to ever fit right, use 16x9 or full on TV remote , then 16x9, stretch 1080i on cable box
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
ZOOM BUTTON STICKING..how do i fix this?
It is possibly an issue with the zoom motor, not the switch itself
4helpful
2answers
I just bought a new insignia LCD TV and the picture does not cover the entire screen. Instead of the 32 inch. diagnal I should, I have a 24 inch picture. Is there something I can do about it?
The "picture size" on the TV needs to be set correctly. You should have a "ZOOM" button on your remote. Press it a few times, cycling through the options... see if this fixes the problem.
Be advised, many (most) HD channels do not show HD content all the time. At the broadcasters discretion, they may choose to ADD the black bars to either side (and/or top an bottom) of the image. This is what the "ZOOM" button is actually for... to allow you to correct this, filling the screen with the image.
*Note: many cable box have a "FORMAT" or "HD ZOOM" button. When used in conjunction with the TVs zoom feature, you can end up having one device set correctly, while the other is not. The result is often a picture that is expanded far beyond the bounds of the displayable area of the screen. If you can not find a solution using the "ZOOM" button, pick the setting which shows the most image. Now adjust the cable box setting (FORMAT / HD ZOOM).
HD TV screen is zoomed to far out. How do
Use the Picture, Zoom, or Aspect button on the TV remote to cycle through the available screen sizes. You may also be able to set screen size in a Setup-Picture (or Video) menu.
ZooMING Problem
You can't zoom when you are in 3MP mode (default highest resolution). The phone can only zoom in VGA/1MP/2MP modes.
To switch modes:
Start the Camera
Choose "Settings"
Choose "Picture Size"
Pick "2 MP" or "1 MP" or "VGA"
Note: Lowering the Picture Size lowers your picture resolution and quality.
Picture Quality Iphone
This is normal. Most pictures you see on websites are small representations. Try going to a wallpaper or background website, click on larger pictures and zoom in then.
As for Youtube, this is normal to have ratty quality videos. this is also dependent on your bandwidth, so it may drop in quality in a low reception area, but wifi should be pretty decent, just still typical YouTube quality.
How to achieve full zoom with a Nikon 55-200mmf/4-5.6G ED lens?!
1) What camera body are you using?
2) I do not understand your assertion that it automatically zoomed in. Zooming is a manual function. The automatic functions of your lens pertain only to focusing on of the subject so that your picture is sharp and ensuring that the correct amount of light is admitted so that you have a correct exposure.
3) Are you sure you were turning the zoom ring and not the f-stop ring? The zoom ring is labeled 200 on one end of the scale and 55 on the other. It is also the widest ring on the lens barrel. When you rotate it, the physical length of the lens will lengthen as you rotate it clockwise (viewed from behind the camera) and shorten as you rotate it counter-clockwise.
4) For reference, at 200mm the angle of view on your lens should be 10 degrees and at 55mm about 40 degrees.
3helpful
2answers
Sony Bravia - Picture in ZOOm Mode
I corrected mine by adjusting my cable settings. It had been set to "zoom" / "wide" mode. I reset to "normal" and now channels look fine again.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
