Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
Lori Martin Posted on Nov 22, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Casio battery door is broken how do I replace it
I need to replace the battery cover
Harrie
Level 3:
Top Expert:
  • Casio Master 6,746 Answers
  • Posted on Nov 22, 2014
 Harrie
Casio Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1286022
Points
83153
If you have enough skills and tools to open a camera, and build it together again, first order a new battery door and all spare parts, needed to put the camera together. While opening a camera, it could be you have to remove glued parts.
If you can't buy a new door from Casio (I think they don't sell it to you if you are not a Casio certified repair centre), please don't even try to open the camera. On ifixit they show hoe to open electronic gear, but they never show how to put it together.
You can look (at your own risk) how they open camera's.Perhaps even yours is on the site too:
Repair Manuals for Every Thing iFixit
1 Related Answer
Anonymous
  • Posted on Jan 20, 2011
SOURCE: battery cover broken
don,t bother looking at this site as it gives no solution to any problems
1helpful
2answers
Casio C-801 batteries.....?
You need two SR1120 or type 391s.
Battery replacement J-10A
Good Morning Fhaas153
Looking at a J-10 picture on eBay
http://www.ebay.com/itm/VINTAGE-CASIO-J-10-ELECTRONIC-CALCULATOR-8-DIGIT-TESTED-/331587643662 , the picture of the rear says '1.5V battery x 2. Looking at this other shot
http://www.casio-calculator.com/Museum/Calculator/FGHIJ/J-10/Casio-J-10-back.jpg It looks like there is a fairly clear Slide-to-Open Battery door at the top of the rear panel. Given the battery rating at 1.5 Volts and the door size, I'd suspect it'll take either AA or AAA batteries. You should be able to slide the door and look, and most battery compartments will have an indication of the specific cell.
To be sure I'm covering both the what and the how, slide the door open. Remove old batteries if still there. Clean up contacts with a bit of fine steel wool if they are corroded or covered with old battery fuzz. Put new batteries in - negative end towards the coil springs generally. Replace sliding hatch.
Hoping this covers what you're looking for!
D
Battery for Casio D-20M
Turn calculator over. Look for some small screws. Loosen them, remove the cover. Notice how the two batteries look when they are in place (polarity) and replace them. Close the cover and tighten the screws again. You need two LR 44 batteries or equivalent.
Powershot sx20 battery cap lock got broken now the cap will no longer close
Use electrical tape for holding the door or you need to visit service center for replacing the complete door.
1helpful
Battery cover broken
Canon digital camera
Same problem here with broken battery cover door! Called Polaroid and NO they do not have these parts to replace....if the camera was under warranty Polaroid would have replaced the entire camera.....soooooo when you find out any info as to where to get the battery door list the info! Thanks! & good luck too!
Replacing Battery in Casio Privia
Not sure about your mouse but ry Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
1helpful
4answers
Replacement Battery Cover Assembly
If you're handy, you can replace it in about 3 minutes. Don't attempt it unless you're willing to risk tearing a thin flexible circuit under the rear cover. Looking at the camera from the rear, remove the screws on the right hand side ( 2 ? ) then the screws across the bottom - open the card door, remove the card, and wedge a knife blade between the front and rear cover halves - the card door will be loose with an attached spring coming free. No need to remove the rear housing completely, just enough to expose the tracks for the battery cover hinge. Remove the old door, noting the position of the opening spring at the hinge, by angling one hinge out first. Insert the new battery cover and the card door in reverse order.
3answers
E-125 Turns off and won't turn on
This is what I suggest: Get yourself a new backup battery. First backup your Casio. Then install the main battery. Plug the Casio in and recharge overnight. Once recharged, install the new backup battery. Make sure you do not touch the battery with your hands. Use a tissue. This should solve your problem if the Casio is not physically damaged.
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Casio Camera Expert? Answer questions, earn points and help others
