20 Most Recent Kodak EasyShare CX7430 Digital Camera Questions & Answers
7answers
Camera Error #E45
after reading the last comment that the guys cat knocked it off the table and he suggested throwing it on the ground it worked...
12/2/2020 11:36:36 AM • Kodak EasyShare... • Answered on Dec 02, 2020
Easyshare 721 battery problems
You need high-power re-chargeables - 2300 mAH or 2500 mAh
5/13/2017 11:39:59 AM • Kodak EasyShare... • Answered on May 13, 2017
How do I format an sd card?
Press the MENU button, use up/down-arrow to highlight Setup (three horizontal slider), press OK, use up/down-arrow to highlight "Format," and press OK.
6/15/2014 5:27:26 AM • Kodak EasyShare... • Answered on Jun 15, 2014
0answers
New batteries, turns on, after date shuts off.
I recommend you see the milliamp-hour (mAh) rating written next to the batteries and your camera, most cameras work at around 2000. You can buy one with more amperage, which will give you more time, but will produce an uncanny heat on more usage. See the rating, and buy accordingly or at the most 500 more from the recommended one. Thank you.
10/18/2013 8:31:57 PM • Kodak EasyShare... • Answered on Oct 18, 2013
Hi There, I have unintentionally 'formatted' a
well ask Kodak. they have help there.all cameras work diffr. you need to work with them.ive never seen any camera that allows the OS, to be erased.wow. but i have seen cameras with one memory,it will lock up if the memory is not reformatted,RTM read the manual , under how to format the memory.then do that. and turn off cam.take out the batteries, for 1 or 2 mins. put them back.now see if it turns. on. if you can get the menus back use the factory reset mode.
10/2/2013 1:09:59 PM • Kodak EasyShare... • Answered on Oct 02, 2013
My Kodak EasyShare CX7430 Digital Camera's flash
I assume there's a subject in the foreground you want illuminated with the flash?The light output from the flash falls off with the square of the distance. An object twice as far from the camera only receives a quarter as much light. If you want your foreground subject illuminated then the background won't get much light. In order to get both the foreground and background illuminated the same, turn off the flash. This will probably require you to put the camera on a tripod or other stable support.You might also want to consider using the Night mode. This mode uses a slow shutter speed to allow the background to illuminate, then fires the flash to illuminate the subject. See http://resources.kodak.com/support/shtml/en/manuals/urg00206/urg00206c2s3.shtml
8/24/2013 3:08:47 PM • Kodak EasyShare... • Answered on Aug 24, 2013
How to switch from internal memory to external memory card on Kodak CX7430
Insert a compatible memory card. The Kodak CX7430 works with MMC and SD cards, 2GB or smaller.
4/19/2013 11:39:22 PM • Kodak EasyShare... • Answered on Apr 19, 2013
How to change from internal to external memory of Kodak CX7430?
Insert a compatible memory card. The CX7430 works with MMC and SD cards, 2GB or smaller.
4/19/2013 11:36:47 PM • Kodak EasyShare... • Answered on Apr 19, 2013
Easyshare will not charge battery
It's not supposed to. The CX7430 is a camera, not a battery charger. If you want to use rechargeable batteries with it, you must charge them outside the camera, or use the dock.
2/24/2013 10:57:35 PM • Kodak EasyShare... • Answered on Feb 24, 2013
My Camera has recently stopped the transfer from Camera to PC after being OK for years?
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
1/31/2013 6:40:16 PM • Kodak EasyShare... • Answered on Jan 31, 2013
My kodak easyshare cx7430 camera has pink in my pictures, how do I get that out?
follow this steps and fix it. God bless youVersion:1.0 StartHTML:0000000168 EndHTML:0000003236 StartFragment:0000000502 EndFragment:0000003219
1. The batteries may need replacement. Somedigital cameras continue to function when their battery power is low, but produce grainy photos with incorrect coloration. Make sure you aren't using Ni-Cd rechargeable batteries, which are generally not recommended for cameras. 2. For the best picture quality, make sure the camera is set to its highest resolution. This may have been adjusted by accident. The process for doing this varies greatly among different digital cameras. Keep in mind that fewer photos will fit in the camera's memory and it will probably take longer to transfer them to the computer, at a higher resolution. 3. Digital photography tends to be more prone to blurring (caused by slight movement of the camera while the photo is taken) than 35mm film, especially with very small or lightweight digital cameras. To remedy this, try using a tripod and/or the camera's timer, if it has one. Adjust the camera's shutter speed if possible. 4. If colors are too pale, using an image editing/viewing program (such as PictureWorks MediaCenter) to increase the Saturation level may be helpful. If the camera has produced colors which are entirely wrong (everything is in shades of black and purple, for example), you can turn the saturation all the way down so that it becomes a black & white photo. 5. The lens may need cleaning. Make sure you use a cleaning material which will not scratch the lens. If possible, refer to its manual for specific cleaning instructions1_30_2013_6_40_51_pm.jpg
1/30/2013 6:40:59 PM • Kodak EasyShare... • Answered on Jan 30, 2013
Kodak EasyShare CX7430 Digital Camera Logo
270 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
switch from internal memory external
  • Cameras
