Philips gemini  XL-300 Turntable Logo
Posted on Jul 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you hook up gemini xl 300 turntables to a gemini pmx 500 mixer
Anonymous
Level 2:
  • Expert 69 Answers
  • Posted on Aug 06, 2009
Anonymous
Expert
Level 2:
Answers
69
Questions
Helped
27119
Points
105
Red n white phono leads from deck 1 to channel1phono ports on mixer
red n white phono leads from deck2 to channel2 phono ports on mixer
then output out to amp
1 Related Answer
A
Anonymous
  • Posted on Aug 16, 2008
SOURCE: gemini xl 500
on top of the pitch control there is a small hole, in this hole you can use a small screw driver  and turn it left and right to free any dirt inside this is the master pitch control
Where to get a needle for Gemini XL 500 II
Look at the cartridge make and model number fitted. Put that into Google and the type of stylus needed will show up.
1helpful
I need a replacement cartridge for the gemini xl 500 ii series and i can't seem to find it in any stores or online.
Maybe this will be of help?
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=GEMSXL500II
I have tried too hook up my Gemini XL-500, to a Sony Digital Audio DTS discrete 6ch Amp , but get very low volume, tuner & cd dvd, volume is fine, does this have anything to do with the ground?...
No! The amp must have a magnetic cartridge pre-amp to increase the sound level. If it has one it will say "phono" on the inputs on the back and have a "turntable" - or "Phono" selector switch. If it doesn't have one (many new surround amps don't) you won't be able to play it properly untill you get a "magnetic cartridge pre-amp". This will make the signal loud enough to be used on a normal aux imput of the Sony.
Cant get my turntables turned on and there connected to my mixer do i need the power cords for the turntables????
if there is a slot for a power cord on the turntables them selves then yes you need the power cords
Gemini xl 500
Turntable problem
You will need a phono preamp. Ipods, radios and cd players all give out a LINE level signal..which means you can plug headphones or speakers, adjust volume and be set. A turntable needs a phono preamp. Usually a dj mixer or stereo receiver with a phono input is all that is needed. A simple phono pre amp is like $20 from radio shack.
keep me posted.
1helpful
Gemini pmx 3501 and xg2000
Here you go: xg-2000: http://www.geminidj.com/disc._prod_manuals/AMPS/XG-2000/XG-2000.pdf PMX-3501: http://www.geminidj.com/disc._prod_manuals/MIXERS/PMX-3501/PMX-3501.pdf Hope this is what you want
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
