Cant get tv to change to channel 3 and cant get to tv in the menu
SOURCE: remote code
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved (remember that at times a bit of
to and fro dialogue may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: User Manual for (Dynex) DX-LCDTV19
Go to the Dynex web site. Type your model number in the search box and follow the link to the user manual.
SOURCE: Program a universal remote for the Dynex 32" 720p Flat Panel
Try using the codes listed for Orion products. Worked for me.
SOURCE: olivia 42'' flat screen and cant get any cabel channels
make sure that you're not using a cable box. then when you do the channel scan, make sure that you pick cable instead of antena.
SOURCE: Need to program channels
This is a LCD tv right?U want to hook up free air or pay cable tv.Go in ur tv menu goto setup,go down to CH.press than pick AIR or CABLE.Than just pick one press scan u will get all free air channels or get all ur pay cable channels
