Uniden DECT 6.0 Cordless Phone ID Logo
A
Anonymous Posted on Oct 17, 2014
HOW DO I CHANGE THE DAY
ANSWERING MACHINE SAYS SUNDAY EVERY DAY
1 Related Answer
Anonymous
  • 3278 Answers
  • Posted on Aug 24, 2011
SOURCE: I have a Uniden Answering
Hello.
From Uniden:
To set the clock on your answering machine:
Press and hold the Clock button until a beep tone sounds.
Next, press the skip or repeat key until the correct day is announced. (Numbers zero
through six display on the base as each day is announced.)
Press Clock again to select the day. The hour setting is announced.
Press skip or repeat until you hear the current hour setting. Numbers 1 through 12 display on the base as each hour is announced.
Press Clock again to select the correct hour.
Press Skip or Repeat until you hear the current minute setting. The numbers 0 through 59 display on the base as each minute is announced.
Press Clock again to select the correct minute. The AM/PM setting is announced.
The LED displays an A or P. Press Skip or Repeat until you hear the correct AM/PM setting.
Press Clock again to end the time/day setting. The EXA7950 announces the time that you have set.
Hope this helps.
How do you change receiving message day and time if they call me on a Sunday the internal voice message says Wed. and it is the wrong time.
Press and hold the STOP/SET button for two seconds to enter the change mode. Full details are in the "Changing the Settings" section beginning on page 10 of the manual at
http://www.home-electronics.net/ge/pc/IB/29875GE1_IB.pdf
1helpful
How do you set the time and date? Thanks
Hi!
First of all you need to set the Language which allows you to set the answer in either English or in Spanish voice menu mode. Once the language is set, all voice menu, including the ones used in Remote access mode, will be switched to the selected language.
1. Press and hold the STOP/SET button for two seconds, then release to access the set-up menu.
2. The answering machine announces, "For English, press NEXT, press SET to continue (in English). Para espanol, oprima PREVIO, oprima PROGRAMAR para continuar (in Spanish)".
3. Press NEXT, answerer enters English voice menu mode. If PREVIOUS is pressed, answerer enters Spanish voice menu mode. If SET is pressed, answerer remains in the current language mode. In any case, the answerer enters to the TIME/DAY menu.
NOTE: Language can only be set when the user is in physical access of the unit. When you are running in Remote Access mode, the language cannot be changed and will remain in the language you’ve previously set.10
Setting the Time/Day : This setting allows you to set the current time and day for the Time/Day stamp attached to each message.
Hour : 1. When you have completed setting the Language, the unit will enter the TIME/DAY menu. The answering system announces, "Time (the current time and day setting) To set hour, press next...press set to continue."
2. To change the hour, press and release the NEXT or PREVIOUS button and the answering system announces an hour, such as "12am, 1am, 2am," or "12am, 11pm, 10pm."
3. After choosing the hour, press and release the STOP/SET button to store the hour. The answering system enters the Minute menu.
Minutes : 1. The answering system announces, "(the current minutes setting). To set minutes, press next...press set to continue."
2. To change the minutes, press and release the NEXT or PREVIOUS button, and the answering system announces a minute such as "1, 2, 3" or "59, 58, 57."
3. After choosing the minute, press and release the STOP/SET button to store the minute. The answering system enters the Day menu.
Range of Settings
Time
Hour 12 a.m. - 11 p.m.
Minute 0 - 59
Day Sunday - Monday
Rings 2,3,4,5 toll saverto Answer
Message time 1,2,3,4, minutes
Security 0 - 9, 0 - 9, 0 - 9Code
Default Settings
Time 12 a.m. Sunday
Rings to Answer 4
Message time 2
Security Code 12311
Day
1. The answering system announces, "(the current day setting) To set day, press next...press set to continue."
2. To change the day, press and release the NEXT or PREVIOUS button, and the answering system announces a day, such as "Sunday, Monday" or "Sunday, Saturday."
3. After choosing a day, press and release the STOP/SET button to store the day. The answering system enters the Rings to Answer menu.
Thanks for using FixYa and do rate the solution as Fixya, if found helpful.
Thanks
Rylee
12helpful
How to set time and date
For example to set wedesday 1:10 am you would:
a: press and hold the time/code button for 2 sec. You will hear announcement "to set code ...... to set time press memo (2-way) button
b: release the time/code button
c: press the 2-way/m button once. You will hear voice prompt set day and time, sunday
d: press the << button or the >> button until you hear wed.
e: press the time code button once to enter the current day and xx hour is announced
f: press the << button or >> button to get to 1.
g: press the time code button once and 1 will be announced and you will hear xx min. announced
h: press the << button or >> button once for each minute as it will gradually increases or decreases to reach 10.
i: press the time code button and 10 will be announced followed by pm
j: press << button or >> button to change am
k: press the time code button once and it should announce the current day and time.
good luck
1helpful
2answers
Cannoty change day of the week, Emerson EM-1200
if you email me your adr - I will be happy to mail you a copy of the user's manual - - thanks Shayla
2helpful
3answers
Instruction Manual
GE Digital Messaging System ~ Voice/Time/Day stamp
1a] press and hold down STOP/set button and wait for promps.....
ie. press NEXT to change Day stamp and then SET to pick.
ie. press NEXT to change Hour and SET to pick.
ie. press NEXT to change Minute and SET to pick.
1b] press NEXT to pick 1minute allowance recording for recieving messages coming in, or 2 minutes or 3 minutes or 4 minutes. This machine only has 1/2 hour of recording time, so maybe you can 'tell' -record- that and let incoming callers know they have only minutes and machine will automatically shut off and cut them off [hang-up] on them.
2] press and hold down Greeting button and follow promps to change the answering machine voice promps to your own voice. Machine will automatically PLAY BACK your voice, if you don't like what you hear, press and hold down Greeting button again and try again.
~ hope all above helps.
4helpful
Change time & day
Does your system have a time/code button? If it does, hold the button down for about 5 or so seconds until you hear the date, then use your arrow keys up above & change to appropriate date & time.
1helpful
2answers
Time and date
Here's the link where you can download the manual.
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=162
I think it will be easier for you to read their directions than for me to try to explain this.
I hate to beg, but so many people don't rate solutions. We don't get paid for this we just like trying to help. If you found this information helpful I hope you'll take a moment to rate this solution.
80helpful
9answers
User manual for a Bellsouth answering machine model 1188
Found my manual!
To set the time, press and hold the time/code button for 2 seconds. You will hear "TO SET CODE PRESS TIME AND CODE BUTTON."
Release the time/code button.
Press the 2 way/m button once. You will hear "SET DAY AND TIME, SUNDAY"
Press the << or >> button until you hear the correct day.
Press the time/code button once. You will hear "TWELVE"
Press the << or >> button until you hear the correct hour.
Press the time/code button once. You will hear "OH".
Press the << or >> button until you hear the correct minutes.
Press the time/code button once. You will hear "PM".
Press the << or >> button if you need to change to AM.
Press the time/code button once and you will hear the complete time and day setting.
To record an outgoing message, press and hold the ogm button. Release the ogm button and start to record after you hear "PLEASE RECORD AFTER THE TONE" followed by a beep tone. When finished, press the ogm button.
Make sure you put a battery in the answering machine so you don't lose these settings if the power goes out!
Time and date
Setting the Clock
You’ll need to set the clock so that it can
announce the day and time that each
message is received. Press P to exit
Setting the Clock at any time.
1 Press and hold C until the
Message Window displays C, and the
default day is announced.
2 To change the day setting, hold down
or until the
correct day is announced. Then
release the button.
3 Press and release C. The current
4 To change the hour setting, hold down
or until the
correct hour is announced. Then
release the button.
5 Press and release C. The current
minutes setting is announced.
6 To change the minutes setting, hold
down or until the
correct minutes setting is announced.
Then release the button.
7 Press and release C. The new day
and time are announced.
To check the clock, press and release
C.
NOTE: In the event of a power failure,
see the instructions on the bottom of the
unit to reset the clock.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
