Protron PLTV-32 Television Logo
A
Anonymous Posted on Oct 15, 2014
When I connect my laptop using an hdmi cord-the tv doesn't receive a signal - why ? I can do it with any other tv with an hdmi input - how can I remedy this??
Level 3:
Top Expert:
  • Protron Master 76,851 Answers
  • Posted on Oct 15, 2014
Protron Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008403
Points
237762
Contact any service technician. Electro help
2 Related Answers
A
Anonymous
  • Posted on Jan 26, 2008
SOURCE: PLTV-3750 37 inch LCD TV no longer sees signals from any AV inputs
crisp audio and video signals.
gopakumarg43
  • 76851 Answers
  • Posted on Nov 26, 2012
SOURCE: protron tv says input signal out of range when connecting laptop via hdmi
The TV can't process the digital signal. It might be out of range.
2answers
Denon AVR-888 does not pass HDMI signal from Asus ux431f laptop to the Vizio tv.
If your Denon AVR-888 is not passing HDMI signal from your Asus UX431F laptop to your Vizio TV, but is passing signal from your Apple TV, there may be a compatibility issue between the laptop and the receiver or between the receiver and the TV. Here are a few things you can try:
  1. Check HDMI cables: Make sure all HDMI cables are properly connected and working. Try using different HDMI cables to see if that resolves the issue.
  2. Update firmware: Check if there are any firmware updates available for the receiver and the laptop. Updating the firmware can sometimes resolve compatibility issues.
  3. Check laptop settings: Make sure the laptop is set to output video through its HDMI port. On some laptops, you may need to manually select the HDMI output in the display settings.
  4. Try a different input: If your receiver has multiple HDMI inputs, try plugging your laptop into a different input to see if that resolves the issue.
  5. Contact the manufacturer: If none of the above steps resolve the issue, contact the manufacturer of the laptop, receiver, or TV for further assistance.
It's also worth noting that some older HDMI receivers may not be compatible with newer HDMI devices. If your receiver is several years old, it may not be able to pass the HDMI signal from your laptop. In that case, you may need to upgrade to a newer receiver that supports HDMI 2.0 or higher.
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Want Connect to My Laptop HDMI Output
If your TV has no HDMI input to connect with your laptop's HDMI output, surely you need a converter. If the laptop have A/V output, and the TV too have an A/V input, you can connect in between, using an AV cord. google.com/+GopakumarGopalan
1helpful
My pc is connected to my tv using an hdmi cord, it frequently cuts out and says no signal
Sounds like either the laptop's hdmi output, or the tv's hdmi input is the problem. You can findout wich one by connecting the laptop to another set and see if it still happens. If it goes away then it is your tv input, if it is still there it is the computer.
Problem with Dell W4201C 42 in. HDTV Plasma Television
Plug the HDMI into laptop and T.V first then turn the laptop on, I have the same problem sometimes just doesnt read it properly if the laptop is already turned on when plugging in to HDMI. Hope this helps
1helpful
Connecting a sony STR-KM7600 to a led tv
If you are using a cable box, then run your HDMI cord into your receiver HDMI input. Then another HDMI cord from thr Reciever HDMI out to your Samsung Hdmi input.
How do you get laptop screen to show on the tv by a hdmi cord
Connect the HDMI cord to both. Switch to the HDMI input on the TV. Boot the laptop. If you're using Windows and the TV doesn't show the laptop's screen, right click anywhere on the desktop that doesn't have an icon, then select properties. In the tab to the right of the resulting window, you should be able to enable screen mirroring, expansion, or switching.
Some laptops also have a function key set that you press to switch monitor outputs. Look for keys with secondary, alternate color commands on them. It will normally take a set of key presses.
How can i watch movies from my laptop onto my tv using the hdmi cord.. i dont get picture or sound..
make sure you are using a highspeed HDMI cable to connect the laptop to the TV, then set your TV input to HDMI/digital. Then set your default playback device on the laptop to HDMI to make sure signal goes from the laptop video controller to the TV. hope this helps, feel free to rate how useful the info is to you
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
What is the correct wiring connection using hdmi and optical cables from a lcd tv to yamaha yht292
If you tv has a hdmi input, connect it to the Yahama receiver hdmi output (out). If you are using a satellite receiver, digital converter, or a cable box with hdmi output(s), connect them to the Yahama hdmi input (in) for video and audio signals. If the above box(es) do not have hdmi capabilities, then connect the box(es) to the Yahama with either component (preferred), svideo, or yellow RCA compsite video jack (least preferred) for the video signal. For audio, connect the box(es) with optical or coax (preferred) or left-right-center-front-rear patch cords.
It really all depends on what outputs are available on the boxes and/or signal source(s).
Hope this helps,
Rhais
Top Protron Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
