How to Clear BIOS Password
Three Methods:Using the Password BreakerReset Jumpers to Clear a CMOS PasswordOther Methods to Clear a BIOS Password
A BIOS or CMOS password is set and entered from a DOS-like prompt after a computer is powered on and before Windows or another operating system loads. If you have a computer with a BIOS password, that has been forgotten, or is unknown, you will not be able to get past the password prompt to boot the operating system or even view what is on the hard drive. Fortunately, there are several methods that can be used to bypass it. Learn these methods to find out how to clear a BIOS password.
Using another computer, load up your Internet browser. Go to this website, and write down the code shown on the locked computer
Unplug the computer and remove all peripheral connections like monitors and printers.
Reduce electrostatic discharge (ESD). Wear a wrist strap to eliminate ESD, or make sure 1 hand is holding a metal piece while you are working inside the computer. Wear rubber soled shoes, and stand on an ESD mat if possible.
Open the computer. Locate the CMOS jumper. The jumper will usually consist of 3 pins, though on the rare occasion, 2 pins (requiring you to supply the jumper itself). This often is labeled with "clear," "cmos," "password" or some abbreviation that indicates it is the password jumper. It is usually located near the CMOS battery, or processor. In laptops, it is often a dipswitch at the bottom of the laptop. Consult your motherboard documentation to find the location if you are unsure of where it is located.4
Make note of which pins the jumper covers. Remove the jumper. Reinstall it so that it covers the pin that is currently not covered. For example, if it covers pins plz help me.... forgot bios password msi mini lapt - 670px-clear-bios-password-step-5.jpg pins 1 and 2.
Reassemble tplz help me.... forgot bios password msi mini lapt - 670px-clear-bios-password-step-6.jpgr. Turn on the computer. Check to see that the password is cleared.
Turn off the computer. Disconnect the power cord, and open it. Change the jumper settings back to the original position.
Search online for generic CMOS passworplz help me.... forgot bios password msi mini lapt - 670px-clear-bios-password-step-8.jpg generic password set by the manufacturer. To find one, search for the name of your manufacturer. Keep in mind that the computer password may have changed or no longer is in use.
Download a utility to bypass the computer password. These can be found online and loaded with a CD or floppy disk.
Take out the CMOS battery. Leave it out for longer than 5 minutes, and then reseat it. This will clear all BIOS settings, including the password. Keep in mind that you will have to reset the BIOS date, time and other settings.
Contact the manufacturer. Find information about the motherboard, and call either the motherboard or computer manufacturer. They can tell you whether there is a CMOS default password or solder beads that must be jumped.
SOURCE: I forgot my pass word and can't get in my laptop
there r many ways u can solve this problembut there isnothing called resetting your natebook.
the best option for u will be take to the nearest service station n they will do the rest, if u knw formating thn u can do it urself
SOURCE: msi u100 bios password
Turn the laptop upside down and remove the plates one by one. Wherever you see a button cell, remove it for a minute or so and then reinsert it and put back all the covers. Power on and boot up the laptop. And remember not to use the password again. And if you have to then use such that you can not forget ever.
SOURCE: My niece has somehow set a password on her msi u10...
Hope this post can help you:
http://www.windowspasswordsrecovery.com/crack-dell-laptop-password.htm
