20 Most Recent
MSI Wind U100-030US Laptop Questions & Answers
I have msi wind net
the vga port must be enable first. using the hot keys told in your free manual MSI.COM
ALSO all batteries here are no good.
both big'n and coin dead.
5/23/2022 12:31:00 PM •
MSI Wind...
Answered
on May 23, 2022
Turns on but black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen. If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
2/18/2019 5:52:23 AM •
MSI Wind...
Answered
on Feb 18, 2019
Msi u100 bios password
Turn the laptop upside down and remove the plates one by one. Wherever you see a button cell, remove it for a minute or so and then reinsert it and put back all the covers. Power on and boot up the laptop. And remember not to use the password again. And if you have to then use such that you can not forget ever.
5/5/2018 12:25:49 PM •
MSI Wind...
Answered
on May 05, 2018
My MSI U100 Netbook won't charge. I purchased
Yes the AC Cord does go bad , you can also look at the power jack at the back of the Laptop to see if it is loose when you plug it in. I always start with the plug they are usually cheaper than a battery.
11/2/2017 10:43:33 AM •
MSI Wind...
Answered
on Nov 02, 2017
MSI WIND U100 won't start....
thats a lil odd seems as if the motherboard is trying to determine what speed of ram you have but after about five mins or more if it doesnt do anything try reseating the ram cards if after five mins again try using just one ram card in one slot if it turns on fully turn it off and move the same working ram card to the next slot if any slot fails then that ram slot is dead if you have more then one ram card test it using the same method if the ram card does not work then that ram card is bad
4/22/2017 8:55:51 PM •
MSI Wind...
Answered
on Apr 22, 2017
Ntldr is missing
Missing NTLDR fix
Windows xp pro.
Windows will not boot and you get a disk read error
NTLDR is missing
To repair this you will need your windows installation cd.
Step 1. insert windows installation cd and restart the computer.
Step 2. press any key to boot from cd.
Step 3. after the files load press r to repair windows. This will open the recovery console.
Step 4. You will see the Windows file... 1: C:\Windows -- Press 1 and enter
Step 5. Type administrator password if you use one and press enter.
Step 6. go to the directory that your installation cd is in... mine is D so type D; and hit enter
Step 7. type cd i386
Step 8. copy ntldr c:\
Step 9. Your done. Now type exit , remove the installation cd, and restart your computer
3/12/2015 3:00:02 AM •
MSI Wind...
Answered
on Mar 12, 2015
I forgot my bios password
If your Laptop has no warranty than you open your laptop back-cover,open your laptop bios battery,turn it on & turn off it again.connect your bios battery again, turn it on and see your bios password has been deleted.
2/25/2015 1:56:35 PM •
MSI Wind...
Answered
on Feb 25, 2015
Cannot remove msi u100 bios
Those are not easy to get to but u will need to dislog the bios battery and re-insert it to remove the password lock.
2/25/2015 10:53:23 AM •
MSI Wind...
Answered
on Feb 25, 2015
My wireless connection works on all the other
hi
check for the necessary ip addressing formats as well as if any DNS server addresses are required to connect to the network
if all is fine then try
right click on the network icon click on repair
try surfing if still not able to surf try the steps a couple of times
cheers
8/13/2014 8:49:18 PM •
MSI Wind...
Answered
on Aug 13, 2014
Unblocking msi u270 bios password
The BIOs Cracker, a free or paid program can be found on line. That will allow changes to be made, however, any interruption can render the Bios useless and you may not access the Boot instruction set henceforth.
1/9/2014 6:18:13 PM •
MSI Wind...
Answered
on Jan 09, 2014
Blank boot screen
It sounds like you have a faulty screen, if under warranty contact support for warranty, otherwise take to a local tech to see if the problem can be rectified.
12/20/2013 11:37:03 PM •
MSI Wind...
Answered
on Dec 20, 2013
How do you turn wifi on msi u130
Press and hold the Fn button, and then press the F11 button repeatedly to enable or disable the 3G/ Wireless LAN/ Bluetooth/WiMax function recurrently.
10/31/2013 7:37:44 AM •
MSI Wind...
Answered
on Oct 31, 2013
