20 Most Recent
MSI Wind UmNotebook Questions & Answers
Camera not working
Factory restore ur system....if it still doesnt work then contact customer care...
Be advised- save ur important data in ext hardisk...as it get lost of factory restore.
1/18/2014 5:19:28 PM •
MSI Wind...
Answered
on Jan 18, 2014
Blank screen
Try unplugging, remove battery, plug in reboot.
6/2/2013 12:45:53 PM •
MSI Wind...
Answered
on Jun 02, 2013
Screen
There is a switch that controls the on/off of display when the lid is opened or closed. Sometimes it's located near the hinges. Perhaps it's been damaged, loose, dirty, etc. Unplug, remove battery, plug in, reboot.
6/2/2013 12:29:43 PM •
MSI Wind...
Answered
on Jun 02, 2013
Built in webcamera driver for msi u100
Hello.
Your problem is not the drivers. The msi u100 webcam is supported by the operating system without the need for installing drivers for it.
Instead, turn it on by pressing and holding the Fn key (bottom left corner) and then pressing F6.
Cheers
11/2/2012 11:42:17 AM •
MSI Wind...
Answered
on Nov 02, 2012
MSI notebook u100 with OS xp built in webcam is not working
MOST issues with PCs and hardware is the SOFTWARE, with that said do the following:1). Locate and download the latest updated driver on the manufacturer's web site. 2). De install the old driver from your PC's control panel.3) Reinstall the latest driver.If you need help locating the drivers or the website then message me back with the PC make and model along with the OS version (e.g. Windows 7, windows XP etc...)
10/29/2012 7:48:53 PM •
MSI Wind...
Answered
on Oct 29, 2012
Hi i have an msi
The moon icon usually indicates that your machine is in SLEEP mode. Try closing and opening the screen lid. If not, there might be a problem with your laptop waking up from sleep mode. Try holding the power button. This will turn it off. Turn it on again by pressing the power button once more. Hope this helps! Have a nice day.
4/11/2011 9:10:29 PM •
MSI Wind...
Answered
on Apr 11, 2011
Mic does not seem to
right glick the speaker ikon then go to playback devices you can enable it there
4/5/2011 5:31:12 PM •
MSI Wind...
Answered
on Apr 05, 2011
Hi I spilled coffe over msi cr360 it boots and
I will try to describe to you in simple terms here. There are a series of screws you will see on the bottom of the lap top. There screws have to be removed all of them before proceeding to clean the computer further. You will also see approx: 3 small screws under the battery when you remove the battery these screws are for the plate that goes across that has the power button etc. Remove those as well then remove the plate and the keyboard be sure to remember where all the screws go back to.
Now the keyboard may need to be replaced it sounds like it was a device that did not make it through the coffee spill and the drying process. There will also be one or two small screws that hold the keyboard down you will see those once you remove the power button plate. Remove those screws carefully take a small screw driver and push the holder for the keyboard cable clip to unlock the clip to remove the cable be very gentle when doing this removal. Observe how it came apart and this will be how to re-install a new keyboard.
You can get new keyboards at Amazon.com this is where I get them at. The process once you get into it and be extremely careful is not that difficult to do as you begin to expose the case pieces once apart. Do not use any wet fluids to clean the parts with. Dry clean only using a soft cloth and take your time.
Enjoy and have fun with it I find it rather interesting more so than a desktop PC repair. Thanks for using FixYa! Do not forget to vote for me John
3/13/2011 12:34:25 PM •
MSI Wind...
Answered
on Mar 13, 2011
How to use my
there could be a software under programs that you can use, webcams are mainly used for websites . you can test to see if it works on facebook, or stickam.
1/21/2011 3:53:55 AM •
MSI Wind...
Answered
on Jan 21, 2011
I have reinstalled the OS
You can get all of your drivers
here. Although, since you do not have the ethernet driver installed, you must download these drivers from another machine with internet access. Then, save them to a flash drive or other media in order to transfer them to your MSI laptop.
12/20/2010 4:56:49 PM •
MSI Wind...
Answered
on Dec 20, 2010
