Watches Logo
Vishnu Posted on Oct 07, 2014
I have a Nautica A13599. The Digital Disply does not show, nor does the LIght come ON. Is it that the Battery has run out ? The Analog hands are working fine !
Question is about: The Nautica A13599 Tachymeter watch, not showing the Digital (World Map etc.) display Do get back to me at [email protected]
5 Related Answers
A
Anonymous
  • Posted on Aug 24, 2007
SOURCE: Fossil JR8096 - Display Not Working
hi i have a watch very simalar. They run on two seperate batteries. sounds like one of them is dead. get the digigtal one replaced
Anonymous
  • Posted on Sep 27, 2007
SOURCE: analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Anonymous
  • 74 Answers
  • Posted on Aug 21, 2009
SOURCE: The digital display shows the correct time but the hands do not.
hi there when you replace batteries in wave ceptors all hands have to be set to the home position (straight up at 12 oclock), as the instructions vary wildly from watch to watch you will have to download the manual from www.casio.co.uk you will need to put in the module number (found on the back plate of the watch), this will be in PDF format, you can download adobe reader for free from www.adobe.com to read PDF files. good luck
Anonymous
  • 61 Answers
  • Posted on Oct 17, 2009
SOURCE: digital/analog watch... analog part doesn't run
A lot of times they hide a second battery for the analog display under the larger battery used to run the digital display. Also, the 2025 may not have a full charge.
Anonymous
  • 2501 Answers
  • Posted on Jan 26, 2010
SOURCE: Watch hands not moving after battery change.
I suspect that there is a setting up procedure that needs to befollowed when the batteries have been replaced. (I had a similarproblem when I did this with my watch - although the hands were moving,they were incorrect!)
I was unable to find any instructions on their web site but if you go to their web site (/www.sekonda.co.uk/) or your own area web site for Seconda, at the top of the page you will see a store locator tab, click on this to find your local store and ask them for some instructions.
Nautica Clipper Analog #N15530G Watch for Men band
NAUTICA BANDS ALLA MODELS
http://www.ebay.com/sch/bluss_929/m.html?item=221887033797&ssPageName=STRK%3AMESELX%3AIT&rt=nc&_trksid=p2047675.l2562
How do I zero the stopwatch hands on my Nautica A 29504 chronograph watch
try www.watchshop.com/mens-nautica-bfc-chronograph-watch-a29504g-p9...
1helpful
Analog on digital watch not working
when a watch has analog hands and has digital portion, 9 times out of 10 it will have 2 batteries inside. A lithium battery and a normal battery. It is possible one died before the other. Usually the lithium (digital portion) lasts longer. Have the battery changed.
Dec 06, 2013 • Watches
3answers
The digital will not sync with the analog hands on my g shock
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
Dec 30, 2012 • Watches
I have the correct time set in the watch, the main analog clock shows the correct time, but the UTC analog hands19:00 when the UTC digital time is 12:00. How do I reset the UTC analog hour hands?
The hands are driven by the digital. It seems to me you have the wrong digital city. Please review the setting instructions for your Skyhawk at: http://www.citizenwatch.com/
BTW, I love my Titinimum Skyhawk
Digital/analog watch... analog part doesn't run
Oct 17, 2009 • Watches
How is time and date adjusted
If the details says "stationary" then this means that the bezel does not move. This is typical in an inexpensive watch such as Nautica, and is probably just for "looks".
Manual nautica watch
I cant aline de hands in 60 line both hands
44helpful
3answers
Analog clock not in sync with digital clock
Top Nautica Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Nautica Watch Expert? Answer questions, earn points and help others
