20 Most Recent Nautica N07574 Wrist Watch Questions & Answers
If you go to the web site www.nauticawatches.com and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Nautica N07574... | Answered on Jul 18, 2015
NAUTICA REPLACMENT BAND http://www.ebay.com/sch/bluss_929/m.html?item=221597748969&ssPageName=STRK%3AMESELX%3AIT&rt=nc&_trksid=p2047675.l2562
Nautica N07574... | Answered on Nov 12, 2014
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
Nautica N07574... | Answered on Jan 27, 2012
The waterproof seal is not woking, or one of the controls was used while the watch was wet, and water came in to the watch. If this is not serviced soon, there will be eventual damage to the movement of the watch.
Jerry G.
Nautica N07574... | Answered on Sep 15, 2008
A good way to find out would be to take your Nautica watch to a jeweler for a demonstration of how to remove the back without damage.
Nautica Watches | Answered on Jun 16, 2019
Take your Nautica watch to a jeweler for a demonstration of how to remove the back. You might be able to persuade the jeweler to install a replacement battery.
Nautica Watches | Answered on Dec 14, 2017
You don't, you take it to your local jeweller who will remove the back and put in a new battery for between $8 and $15 depending on the type of battery, silver oxide or lithium. All done whilst you wait or shop.
Nautica Watches | Answered on Dec 13, 2017
Nautica N07574 Wrist Watch Logo
Popular Tags
19 questions posted
Top Nautica Watches Experts
Arturs Kalnins
Arturs Kalnins
leadfoot44
Are you a Nautica Watch Expert? Answer questions, earn points and help others
View Most Popular
Nautica Watches
  • Nautica Watches
Most Popular Question
buy new white resin nautica watch band
  • Watches
