I touch the 'upper/lower' on the control panel but it does not respond. All other areas respond fine. No codes or anything.
See this: http://www.fixya.com/support/t9354756-thermador_built_in_oven_scd302_not
You might be able to fix by resetting. Disconnect power (probably easier to turn off circuit breaker).
SOURCE: Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
SOURCE: The LED control panel on my Thermador double oven is out
I solved this. Its a vaccum flourescent display. The voltages that drive it are reducing because the capacitors on the control board deteriorate with temperature. Replace the 3 capacitors and its good as new.mine still working after 2 years...$.20 at radio shack...or have a repair place do it for you...saves $250 for a new board
SOURCE: The upper oven works fine. The lower oven won't
Make sure you hit the reset switch first... on top of the lower over... behind the panel...they trip easy and "kill" the oven.
SOURCE: I have a whirlpool rbd245pbd8
Hi
I'd guess you have a wrong wiring connection it sounds as if you may have crossed over the live input and output wires which would give you this condition.
Um, fixed it by turning off the breaker for a few minutes,( found this idea in another thread), it reset itself, hopefully for good. Thanks
