Look in the manual under maintenance minder i believe. you match the Letter and the Number(s).
(B)
Replace engine oil and oil filter
Inspect front and rear brakes
Check parking brakeadjustment
Inspect these items:
Tie rod ends, steering gear box, and boots
Suspension components
Driveshaftboots
Brake hoses and lines (including ABS)
All fluid levels and condition of fluids
Exhaust system
Fuel lines and connections
(1)
Rotate tires
(3)
Replace transmission fluid
Driving in mountainous areas at very low vehicle>
speeds or trailer towing results in higher
transmission temperatures.
This requires transmission fluidchanges more
frequently than recommended by the Maintenance
Minder. If you regularly drive your vehicle under these
conditions, have the transmission fluidchanged
every 30,000 miles (48,000 km).
Honda Odyssey Forum Odyssey Minivan Forums
SOURCE: Can regular mechanic replace brakes on Honda
Yes you can, all you need to do is a normal brake service. The run flat tires are nothing special for your task. You remove the wheels as would any other vehicle.
SOURCE: it honda 2006 owners manual
Hi, you can access an online manual here: http://techinfo.honda.com/rjanisis/pubs/OM/HJ0606/HJ0606MAINIXA.pdf
you may have to establish an account to access the link--I'm not sure.
This link is only the table of contents, but each link in the table of contents will bring up a chapter of the manual.
Please lt me know if you have trouble accessing the link, and thanks for using FixYa.
SOURCE: owners manual 2006 honda odyssey touring
Please see the following link:
https://techinfo.honda.com/rjanisis/pubs/om/HJ0606/HJ0606MAINIXA.pdf
Regards,
Icom1
