20 Most Recent Honda 2012 - Odyssey Questions & Answers
look in the manual under maintenance minder i believe. you match the Letter and the Number(s).
(B)
Replace engine oil and oil filter
Inspect front and rear brakes
Check parking brakeadjustment
Inspect these items:
Tie rod ends, steering gear box, and boots
Suspension components
Driveshaftboots
Brake hoses and lines (including ABS)
All fluid levels and condition of fluids
Exhaust system
Fuel lines and connections
(1)
Rotate tires
(3)
Replace transmission fluid
Driving in mountainous areas at very low vehicle>
speeds or trailer towing results in higher
transmission temperatures.
This requires transmission fluidchanges more
frequently than recommended by the Maintenance
Minder. If you regularly drive your vehicle under these
conditions, have the transmission fluidchanged
every 30,000 miles (48,000 km). Honda Odyssey Forum Odyssey Minivan Forums
Honda 2012 -... | Answered on Feb 22, 2015
Did you pull out the radio. It might have the code on the radio
Honda 2012 -... | Answered on Dec 09, 2014
Blocked main jet in the carburetor. Remove, strip and clean.
Honda Garden | Answered on May 12, 2019
Check into the store that sells Honda's mowers or where you bought that mower. Sometimes you can find what your needing at garage sales or on the Internet for used decks.
Honda Garden | Answered on May 11, 2019
try hondas website then.
Garden | Answered on May 10, 2019
you have to use the right nozzle...low pressure
Honda Garden | Answered on May 06, 2019
rpms are too low at full throttle
Honda Garden | Answered on May 02, 2019
there's no diagram. If your drive cable is kinked it wont release properly and cause this issue. also if the adj arm pivot bushings are worn it will **** sideways and cause this issue
if reverse order of taking off the old one
what about it?
Honda 2012 - Odyssey Logo
4 questions posted
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
View Most Popular
Honda Garden
  • Honda Garden
Most Popular Question
code b13 telling me 2012 honda
  • Garden
