Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
A
Anonymous Posted on Sep 30, 2014
<!-- from fixya rte -->How do I retrieve dialed numbers - Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
I deleted dialed numbers on my Nokia N70 pls help to find them
its not possible to retrieved deleted dialed numbers from your phone because you phone does not have a recycle bin. A computer as recycle bin that's why deleted files are retrieved.
Contact your service provider, they should be able to give you a list of your dialed numbers. Usually, your service provider keeps a record of all your incoming and out going calls.
So try your service provider.
Good luck.
Voicemail retrieval issue on my treo750
Your voicemail number on your phone is usally different than your own number. It's called a "retrieval number" which your provider has. You will need to contact them and get this number and they should be able to assist you with reprogramming the number into your phone. Hope this helped.
1helpful
2answers
How to retrieve dialed number in nokia 1600?
Just press the "Call" button (the green handset key on your keypad) and all your previously dialed numbers will show.
Retrieve a deleted dialed number in nokia1600
How can recover deleted number in nokia 1600, Plz help me or any sugesion plz mail me as [email protected]
Retrieve last 10 dial out number
Same as the other one
It will mainly depend on the setup but usually the last 10. TO access the last 10 select the soft key menu button, down arrow on silver dial to outgoing call log. Let me know if that helps.
Retrieve the latest 10 dial out number
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Retrieve messages
To connect with your answering system:
1 Dial your telephone number from a touch tone phone. 2 When the system answers, enter your Remote Access Code. The system announces the number of messages and begins message playback. 3 Listen to your messages
Change remote access code Press [*] [#]. Follow prompts to set new code.
1helpful
2answers
RETRIEVE MESSAGES
To retrieve a message from another location, dial the telephone number and when the greeting message starts punch in your four digit code. The default code is 0123 if you haven't set one. Follow the prompts to listen to messages.
Top Carrier Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
