SOURCE: Haier AC Problem Troubleshoot.
Your compressor is faulty, you could test this with an ohm meter or a mega tester to confirm that you have continuity between windings and earth or that the insulation on one of the start or run windings has overheated and broken down. Before you give up though, you can try to change the compressor capacitor, with same rated microfarad capacitor.
SOURCE: Brisk air, dometic rv a/c unit I can't get the
you must check the amp draw with a meter to verify if the compressor is locked up. if it draws L.R.A. amps which should be listed on the compressor it is lock up and needs replaced.
Phil
SOURCE: AC compressor won't start
hi,you might need a new compressor...you will need need to go back were you bought capacitor...buy a hard start capacitor too..this might crank the compressor...hope this helps.if you buy it..call an ill tell you how to wire it...if it dont ,you need new compressor...call michael..doctor airr..appl.repair...843-384-8474...
SOURCE: I'm purchasing a generator to
You will need at least a 5000 watt generator to run that and a few lights etc... for the camper.
heatman101
