Red light flashes rapidly - tried priming the machine and still rapid flashing red light.
Have you tried draining off some back-pressure. That often is what the rapid flash means. Try pushing the hot water button then opening the steam valve. A few seconds after the pump comes on to push water out, the red light should go off. If it takes more than a few seconds, that's probably not the problem. hope this helps.
First step: check the flow turbine. If the pins are corroded, change the turbine.
You may need to perform the descaling process
1- Get the descaling liquid
2- Fill the water recipient and add the product
3- Press the water dispensing button and using a glass recipient, pour water from the hot water spout for 15 seconds
4- turn off the machine for 15 minutes
5- Turn on the machine and pour water again for 15 seconds
6- redo the preceiding steps until all water has been used
7- Rincing: Clean the water recipient and refill it
8- Restart the machine and press the hot water button
9- Open the hot water spout button and let it run until all water from the recipient has been used
Et Voila
SOURCE: Re Odea Giro Plus - Cannot stop the red alarm
The problem is with the flow meter which is a turbine unit that is installed before the pump.Either there is a blockage or the unit is bad.Have to open the machine to get into it.
