20 Most Recent
Saeco Odea Giro Espresso Maker - Black/Silver Questions & Answers
Why won 't descaling process begin?
everything what you have to do is to turn hot water to start,then after 10-15 seconds stop machine and turn it off. Wait about 10 minutes and rinse rest of descaling agent.Then fill the watertank with fresh water and rinse again trought hot water. When the water finish your machine is descaled.Then press hot water/steam button for 5-6 seconds and light go of. That is all.
Brew group popped out and cannot put in back in
Make sure that you place the brew group the same way that you usually do after you take it out ie. make sure that the coffee grind collector is sitting vertically, and is depressed down. You may need to jiggle and move the pieces around for this to happen. Then make sure that you depress the tab in the center fully to the right until it clicks before trying to place it back in. Lastly, make sure that you clean any coffee grinds that may be sitting on the surface and which may prevent you from placing the brew group fully into the machine. Hope this helps, good luck!
Red alarm light permanently on!
Hi.
First turnthe machine on.
Then take out everything watertank, dreg draw and brewingunit and have the door opened to the brewing area.
have them out for about 1 minute and then put it back together again.
if this dosent help please check if the machine respond to removing the dregdraw, beanlid.
It will do it by making the constant red ligth flash instead.
if they respond make sure that the watertank is filled to max.
if that is the case it is the watertank sensor that is broken.
Red ! flash frequently
So many faults can cause this problem.The most common is the brew unit requires cleaning and regreasing as per the instruction manual.
