Once we leveled our Electrolux slide in gas range, using it's feet, it created a gap between the left side and the countertop. Is there a filler (removable when necessary) we could use for this gap?
Thank you for your post, Wendy Berg!
I understand that you are searching for a filler piece to go between your Electrolux range and countertop. I was unable to locate any type of filler piece I see the manufacture has a side trim kit, rear filler panel, and backguard kit but nothing specific to your request. I hope this information is helpful. -Matt
Hello friend, thank you for your post!
I understand that your Electrolux range burner buttons are remaining on. I have identified a few possibilities as faulty burner buttons, bad switches, or a disruption inside the control panel. Let's perform a reset on your range which can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue I would suggest consulting with a professional for proper repair. Hopefully this helps. -Matt
