20 Most Recent Electrolux Band Aerus Lux Legacy Canister Cleaner Questions & Answers
0answers
How do you access the motor and guts of an Aeruslux or Electrolux Canister Vacuum Cleaner
Hi, I can help. Flip the canister on it's back. Remove all crews. Should pull apart from there. If not check around body to see if it's clipped. You may have to pry the sides apart. That will give you access. Be careful and pay attention to where everything is. Good luck.
8/4/2014 5:15:49 PM • Electrolux Band... • Answered on Aug 04, 2014
Electrolux legacy,plug light on,bag light on,replaced bag, still no power
Bad on/off switch? Possible contact problem inside the cord reel?
8/4/2014 5:03:53 PM • Electrolux Band... • Answered on Aug 04, 2014
Have a lux legacy c 153c made by aerus comes on and runs fine for maybe 90 sec then shuts off and in about 90 sec will come back on .has great suc and runs great while runing
Is the motor overheating? Or is it more like there's a loose connection in the on/off switch? What happens if you reel in the cord a little? Could be there is a spot somewhere in the rings which is corroded or worn out and not making contact. Might also be a break somewhere in the winding inside the motor. I have a similar situation in my Aerus C15C3. An Aerus brand bag ruptured inside my vacuum cleaner, but I didn't realize until the motor started making a horrible noise! To make matters worse, I hooked up my older Electrolux LE 1623 and at tried to suck as much debris out of the air intake at the bottom of the bag compartment, and then put the C15C3 back into service. I should have stopped then and there and started working on trying to get the motor and the fan out of the housing. But my machine was overheating and shutting off. Sears Parts Direct has diagrams of the Electrolux LE 1623 on their website. The good thing about Aerus and the old Electrolux-USA is that they all have similarities in their design, but Aerus does like to tweak their design just enough to foil or at least complicate access to DIYers and general vacuum repair shops. I hope you post what you find out!
8/4/2014 4:46:17 PM • Electrolux Band... • Answered on Aug 04, 2014
Reset buttton location
The reset button for the power nozzle in on the top of the housing just to the right of the wand to tool connection. As for the tank; this is more a guess than an answer: There is a small hole at the bottom of the bag compartment. I wondered if that was a reset button, but the manufacturer recommends disconnecting the machine until it cools down and resets itself. I know it is not much help. Electrolux Aerus does not want customers to repair their own equipment, and they will refuse to give out information.
7/25/2014 1:38:59 PM • Electrolux Band... • Answered on Jul 25, 2014
Electrolux lux legacy
open up the unit, locate the cord reel, manually retract it to tighten the clock spring. should work again. lookout for broken plastics
7/22/2014 2:23:53 AM • Electrolux Band... • Answered on Jul 22, 2014
2answers
Resetting filter indicator on Electrolux oxygen air purifier
Hi! I hope this tips might help you out .
*Plug in air cleaner and press POWER button until short “beep” sounds. . Press the RESET FILTER button by gently inserting a paperclip into the RESET FILTER hole on the control panel. The light will flash 5 times before a “beep” sounds to indicate the filter has been reset.
Thank for using fixya .
4/13/2020 6:15:28 PM • Electrolux Air... • Answered on Apr 13, 2020
0answers
Ionic Pro Platinum TA750 Air Purifier. It will not turn on?
Question edited for clarity and toss in some CAPS. Question moved from Televisions category. Contact their Support for a warranty repair. https://www.envion.com/en/ta750 ..
12/12/2023 5:16:43 AM • Air Purifiers • Answered on Dec 12, 2023
I have an Afloia Air Purifier. The red light keeps blinking?
Question edited for clarity, dreadful spelling and typos. :>D Question moved from Televisions to Air Purifiers. Your air filter is dirty and needs cleaning.
Afloia Air Purifier Blinking Red - Repair, Care and ...
https://plentifulair.com > afloia-air-purifier-blinking-red... A flashing red light in all Afloia air purifiers indicates that the air filter needs to be replaced. Typically, in these air purifiers, the red light turns on ... ‎Why is My Afloia Air Purifier... · ‎How to Replace the Air Filter in... ..
11/7/2023 2:12:50 PM • Air Purifiers • Answered on Nov 07, 2023
Lost remote can I download one or an app for it please.
Question edited for clarity. Question moved from Cars and Trucks. From the maker https://www.google.com/search?q=Fresh+Air+by+Ecoquest+replacement+remote ..
11/7/2023 5:38:27 AM • Air Purifiers • Answered on Nov 07, 2023
My 20w aspectek bug zapper has stopped working, both bulbs off
Turn off the power button and Unplug the bug zapper. Turn off and Unplug Discharge Bent down and Remove Rotate and Replace the bulbs
8/27/2023 12:59:29 PM • Air Purifiers • Answered on Aug 27, 2023
Electrolux Band Aerus Lux Legacy Canister Cleaner Logo
Popular Tags
16 questions posted
Top Electrolux Air Purifiers Experts
eVacuumStore.com
David Kassin
David Kassin
Are you an Electrolux Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Air Purifiers
Most Popular Question
electrolux lux legacy
  • Air Purifiers
