Onan Cummins Deluxe Remote Start Panel w/ Hour Meter For RV Logo
A
Anonymous Posted on Sep 25, 2014
How to test ignition coil on onan rv generator?
No spark at spark plug
Renee F
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Onan Expert 573 Answers
  • Posted on Feb 19, 2015
Renee F
Onan Expert
Level 2:
Prodigy:
Answers
573
Questions
0
Helped
248208
Points
680
What model Onan generator? Be more specific.
1 Related Answer
Anonymous
  • 6468 Answers
  • Posted on Aug 30, 2012
SOURCE: Onan microlite 4000 Model-4KYFA26100B, Will not start not getting a spark, i have changed the coil wire still no spark
check the low oil shut off system
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
My onan 4.0 grenerator motor will not idle and it is back fireing while trying to run is in the valves
If it is backfiring even during idle, there are a couple of possible issues. Check the obvious and least expensive first. Make sure you have correct OEM spark plugs, check ignition wires. Then check the ignition coil and trigger module, there is a procedure for doing that in the Cummins Onan manual. A manual can be obtained from http://www.advanced-power-technologies.com/ or local Onan RV dealer. This will give you the ignition coil resistance and the ignition module resistance. Also has anyone messed around with the carb, or has it sat for long periods, too lean a fuel mixture can cause backfiring. Good Luck ;)
2answers
Onan 5.5 Hgjab Generator Manual
Gap is 0.025" plug is a NGKR BPR4EY
Cummins part # 167-1638
Onan 4000 generator has no spark
If there is no spark, the ignition module may be bad, or the wiring to it. Have the module ohmed out. Also the magnetic trigger assembley that is on the rotor that sweeps past the ignition module maybe broken. If they check ok, suspect the control board
Manuals for Onan 6.5NH-3CR/16004P RV generator
onan mcgraw RV model NH-3CR/1600HP, need to know how much oil,what weight of oil how much etc, the type of spark plug , oil filter, all the specs
Aug 04, 2010 • Garden
Onan generator service codes
Check the spark plug and the ignition coil for good sparking.
Get the spark plug out, or with another spark plug connected to high voltage cable, outside the motor, the outer part of the plug connected to motor ground and see if spark is present at cranking.
Top Onan Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
