20 Most Recent Onan Marquis Gold Quiet Gas Generator 5500 Watt by Cummins Onan Questions & Answers
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Onan Marquis... | Answered on Apr 11, 2019
Try under the bench seats around the table, near the heater.
Onan Marquis... | Answered on Aug 15, 2015
Check fuel pump pressure, how long has it sat. What load is on after it stops?
Onan Marquis... | Answered on Feb 19, 2015
Does it bog down? if so have engine checked for ability to deliver HP. Cylinder compression, leakdown test. When was it tuned?
Is this gasoline or propane fueled?
Onan Marquis... | Answered on Oct 06, 2014
What is the question? You want a free service manual?
Onan Marquis... | Answered on Nov 17, 2013
Code 32 is a low cranking speed sense. You didn't mention a Spec # which would help. You say batteries are ok, but the generator is not getting enough cranking amps or voltage to maintain the control properly. Check, battery voltage, wiring, any in line isolation solenoids, check generator solenoid, also make sure there is no mechanical binding on the generator, a good way to do that is remove the spark plugs DISCONNECT THE BATTERY to prevent starting, underneath where the air intake is under the alternator is a plastic plug, remove that and you can put a socket I believe 3/4" up onto the alternator shaft and rotate the engine, if it tuns freely there is no binding, if you feel it is hard to move, check the drive train, belts, pulleys underneath (A lot of work, best to take to a dealer if it is mechanically bound)
Onan Marquis... | Answered on Nov 15, 2013
sounds like u need a new fuel pump when u first start up fuel has seaped back to tank only when u crank it brings fuel back up then the speed keeps fuel ok , replce fuel pump shud b ok then.
Onan Marquis... | Answered on Oct 11, 2013
It is a screen on the muffler output, also remove the plug on the bottom of the muffler to remove carbon
Onan Electrical... | Answered on Feb 19, 2015
Some Onan 4KW do not have auxiliary battery charge windings and rectifier. Are you sure you have one? If not you will need and external charger
Model spec number? be more specific please
Which motor, which generator model and Spec
Contact www.advanced-power-technologies (Cummins Dealer) with exact model and spec number. Also there are cold weather options, and cold weather models. Many people buy the RS units of the net, only to find they have been stuck with warm weather models, and they don't start. Does it show a code, or a code 45.
What model? Please be more specific.
Again, what generator model? Onan have thousands. Be more specific please.
Onan Marquis Gold Quiet Gas Generator 5500 Watt by Cummins Onan Logo
12 questions posted
Top Onan Electrical Supplies Experts
bobalix
Lawrence Oravetz
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Onan Electrical Supplies
Most Popular Question
onan 5 5 generator cranking over very
  • Electrical Supplies
