Honeywell Heat/Cool Thermostat Logo
Posted on Jul 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changing the thermostat on 2002 dodge ram 1500
Need to fix the problem
Anonymous
Level 2:
  • Expert 34 Answers
  • Posted on Jul 03, 2009
Anonymous
Expert
Level 2:
Answers
34
Questions
0
Helped
12276
Points
114
Thermostat's are typically not difficult to change. They are usually located in the housing where the upper radiator hose connects to the engine. Consult a repair manual for your vehicle before attempting this or any repair.
2006 Dodge Ram 1500 5.7 4x4. What fuse runs the 4x4 please?
It isn't specified. There is more than one fuse that covers transmission. You would need an auto electrician or a transmission expert to connect a pro grade scan tool computer and diagnose if the switch or solenoid is faulty. A scan tool at this level is bi-directional and can command solenoids to operate and confirm that they do.
https://www.google.com/search?q=auto+electrician+near+me
Fuse Box Diagram Dodge Ram 1500/2500 (2002-2009)
https://fuse-box.info > dodge > dodge-ram-1500-2500-...
Fuse box diagram (location and assignment of electrical fuses) for Dodge Ram / Ram Pickup 1500/2500 (2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009).
2006-2009 Dodge Ram 1500/2500/3500 Fuse Box Diagram
https://knigaproavto.ru > ... > Dodge > Ram (Pickup)
Nov 16, 2018 - 2006-2009 Dodge Ram 1500/2500/3500 Fuse Box Diagram ; 5, 20, except Base: Sunroof ; 6, 40, Diesel ('06): Wastegate Solenoid, Drive Fan Radiator ; 6 ...
2006 5.7 ram 1500 fuse box diagram - DodgeForum.com
https://dodgeforum.com > ... > 3rd Gen Ram Tech
3rd Gen Ram Tech - 2006 5.7 ram 1500 fuse box diagram - I was hoping somebody had a fusebox diagram kicking around. The inside of my fuse box cover does not ...
Fuses and relay Dodge Ram 2002-2008
https://fusesdiagram.com > Dodge
Mar 27, 2017 - For Dodge Ram 1500, Dodge Ram 2500, Dodge Ram 3500 - 2002, 2003, 2004, 2005, 2006, 2007, 2008 model year. Cigarette lighter fuse - Fuse box in ..
2006 Dodge Ram 1500 Quad Cab 4.7 V8. Where is the fuel pump relay and fuse please?
Question edited for clarity and add maker.
Question moved to model category.
In the link
1helpful
I have a 2002 dodge ram 1500 quad cab. the gauges
Check your fuses. This a common thing that can come up often if you have changed from stock stereo equipment to after market, or just because of old fuses.
Once you locate the fuse box, it should give you a diagram of which fuses go to the different lighting systems in your car. Replace them and the problem should be fixed.
If the problem is not fixed from that, then have your wiring checked throughout the truck.
Where is the thermostat on my 2002 dodge 1500 van and how do you change it?
hi this can be found by locating the top hose on the radiator, follow it back to the engine/motor, there you will find a housing inside the housing you should find the thermostat..you need to drain the cooling system Remove the radiator hose clamp and radiator hose at the thermostat housing, Remove the thermostat housing mounting bolts, remove thermostat housing ,then you can remove the thermostat it self thermostat...hope this helps happy 4th to you
1helpful
2002 dodge 1500 Changed radiator, thermostat, and hoses. No heat
Why was radiator replaced?Did it have heat before ? If it was plugged, the heater core may also be plugged. Try flushing it with a water hose in both directions. I dont know why the botton radiator hose would be cold, the radiator should be a uniform temp and the air coming through the radiator should be HOT, when the engine is at operating temp. What condition was the old coolant? if it was rusty, the water pump may have lower flow than normal.
I have a 2002 dodge ram 1500 pickup w. hwat issues
is this a problem w/ the interior vents? maybe stuck venting in outside air rather than from the heater box? did the heat only stop working after the radiator/hose install? if so, then you probably have a big air pocket stuck in the heater core.
3helpful
Thermostat in 2001 dodge ram 1500
the thermostat is located where the upper radator hose comes off the engine there are two bolts or nuts remove hose and remove housing you will see the thermostat when you do clean old gasket material off block and reverse removal procedure
Top Honeywell Measuring Tools & Sensors Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Honeywell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
