Purchased a model off the floor, shop forgot to tell us it was in demo mode and how to deactivate it.
DEMO Mode
The oven can be set to operate in a demo (eg in a retail
store) mode. In this mode the oven does not actually heat
If the oven has been inadvertently supplied in this mode.
The following instructions demonstrate how to exit this mode.
1. Ensure the oven is in the off state. Press and hold the +
button until a beep sounds. The 'Demo' text will begin
to flash.
2. While holding the + button turn the function selector to
the first oven function until another beep is heard.
3. Then turn the function selector to the 'off' position.
4. Release the + button.
5. Toggle and hold the temperature selector to the right (+)
until 3 beeps sound.
The 'Demo' text will no longer be lit and the oven will
function normally. If the 'Demo' test is still present then
repeat the above procedure.
SOURCE: floor model will not come out of demo mode.
If following dirctions from your owners manual does not do the trick. I would call for a tech to look at it. Every thing is control by dispenser board on a PSS26P
SOURCE: Have model PSS26PSWA with LCD
Hold down the home and help buttons at the same time for about 3 secs and it will come out of demo mode
SOURCE: resetting the demo mode
turn off with OFF sw.
Press WARMER / COLDER sw for 5 seconds
While maintaining warmer / colder turn ON with ON sw.
SHOULD NOW TURN ON
