Ricoh Aficio 1232C Color Copier Logo
Christian Posted on Sep 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Copies and prints are always approximately 7 millimeters too much in the left side
Is it possible to adjust the left margin to the original position?
Copy Quick Digital
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Nov 26, 2014
Copy Quick Digital
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
16978
Points
40
First check if the side guides in the paper drawer have opened up slightly
paulfvincent
Level 2:
Champion:
  • Ricoh Expert 208 Answers
  • Posted on Nov 23, 2014
paulfvincent
Ricoh Expert
Level 2:
Champion:
Answers
208
Questions
0
Helped
58757
Points
249
You have to go into service mode.
Testimonial: "Thanks for answering. I am a normal user with some technical knowledge. please give me further information. what code must i press for getting to the service mode? which specifications must I change?"
  • 2 more comments
  • paulfvincent Nov 23, 2014
    From your description the lead edge needs to be adjusted. Go into service mode. SP Direct is probably already selected so enter:
    SP1001-___ Adjust it and make a sample copy and keep doing that until you move it to where you want it.
    This adjusts the lead edge registration. If you need to go the other way the . symbol will change to negative value.
  • Christian Nov 24, 2014
    there is written: Plain, Thick, OHP for Tray1 to Tray2 and Tray3, Tray4. What must I do?
3 Related Answers
Anonymous
  • 74 Answers
  • Posted on Mar 27, 2010
SOURCE: Ricoh 1224c prints on left side only - Blank on right side
well if its just on the black then it might be the black drum see if it does the same on the color from copying and printing. If it does the same in color then its not the drums it may be the developers, but you wont know untill you test the color if it only happens in black and white its definitely a problem with the drum.
Anonymous
  • Posted on Apr 17, 2011
SOURCE: Hi Ricoh 1232 copier and printer.
SC543 infotec isc 1032
e_solutions
dhammika
  • 13 Answers
  • Posted on Sep 19, 2014
SOURCE: copies and prints are always approximately 7 millimeters too much in the left side on the paper
you need to adjust the lead edge trim
press yellow C and 107 and press and hold red C button
then go to copy SP
select 2 drum
then look for trim adjust
and then select front
then change values up and down until you get the correct registration. you can do a test copy while on SP mode by pressing copy window.
Testimonial: "I did change the trim adjust for "front" without any effect. Is there an other adjustment to do?"
Copies and prints are always approximately 7 millimeters too much in the left side on the paper
then go to copy SP
select 2 drum
1helpful
Toshiba e233 photocopier does not coincide with the top margin of the original copy
Top margin??? SEF or LEF
1. If it is the lead edge registration, go to 05 mode and adjust the values of the following...
440 > start > adjust value (for upper drawer margin)
441 > start > adjust value (for lower drawer margin)
442 > start > adjust value (for bypass drawer margin)
443 > start > adjust value (for LCF)
2. If it is the side registration, adjust it from the drawers.
Twosided copying problem
Try turning original in a different orientation i.e. horizontally vs vertically on top of glass, under lid. Jimmy
2answers
I have a Ricoh Aficio 1013 that prints fine but copies are unclear and off
Problem Cause Solution Colored lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About this Machine . Copies appear dirty. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies appear dirty. Auto Image Density is not selected. On the control panel, select [Auto Density]. The reverse side of an original image is copied. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . The reverse side of an original image is copied. Auto Image Density is not selected. On the control panel, select [Auto Density]. A shadow appears on copies if you use pasted originals. Image density is too high.
  • Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference .
  • Change the orientation of the original.
  • Put mending tape on the pasted part.
The same copy area is dirty whenever making copies. The exposure glass, scanning glass, or ADF is dirty. Clean them. See "Maintaining Your Machine", About This Machine . The same copy area is dirty whenever making copies.
  • The original that has already been printed is scanned.
  • Original Type is set to [Text / Photo], and an original with text and photographs that can hardly be distinguished from each other is loaded.
On the control panel, press [Generation Copy], and then begin copying. Copies are too light. Image density is too light. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies are too light. A light copy may result when you use damp or rough grain paper. Use recommended paper only and be sure its storage environment meets the recommended temperature and humidity conditions. For details about recommended paper and the proper way to store it, see "Recommended Paper Sizes and Types" and "Paper Storage", About This Machine . Parts of images are not copied. The original is not set correctly. Set originals correctly. See "Placing Originals", Copy and Document Server Reference . Parts of images are not copied. The correct paper size is not selected. Select the proper paper size. Parts of images are not copied. Even if you place originals in the ADF correctly, margin of a few millimeters on all four sides of the original might not be copied. Use "Create Margin" function to reduce the image of its original size.
For details about missing image area, see "Missing Image Area", Copy and Document Server Reference . images appear only partially. The paper is damp. Use paper that has been stored in the recommended temperature and humidity condition. For details about the proper way to store it, see "Paper Storage", About This Machine . Black lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The dustproof glass is dirty. Clean the dustproof glass. See "Cleaning the Dustproof Glass", About This Machine . Copies are blank. The original is not set correctly. When using the exposure glass, face the originals down. When using the ADF, face them up. A moir? pattern is produced on copies. Your original has a dot pattern image or many lines. Place the original on the exposure glass at a slight angle. Black spots appear on the copy of a photographic print. Because of high humidity, the photographic print has stuck to the exposure glass. Place the print on the exposure glass in either of the following ways:
  • Place an OHP transparency on the exposure glass, and then place the print on the OHP transparency.
  • Place the print on the exposure glass, and then place two or three sheets of white paper on it. Leave the ADF open when copying.
White stripes appear on the OHP. Fragments of paper are stuck to the OHP. Use a dry cloth to wipe any paper fragments off the back of the OHP. The image on the back side of duplex copies has mottled blank patches or is smudged. Missing patches and smudges are caused by moisture leaking from the paper.
  • Do not install the machine in areas that are susceptible to low temperatures.
  • Use paper that has been stored where temperature and humidity conditions meet the limitations we recommend. For details about the paper storage conditions we recommend, see "Paper Storage", About This Machine .
  • Install the Optional anti-humidity heater. For details about the anti-humidity heater, contact your service representative.
When You Cannot Make Clear Copies
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
Missing left edge
Sounds like you should first try the toner cartridge. Make sure you shake it and reseat it in the unit. Print a report. Data Reg., Report
Let me know if problem persists.
Missing left edge
try to change the settings of the printer. maybe your document is on portrate position and your margins.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
