Is this a vent im just at wits end not noing what the other hole in the gas tank is for
SOURCE: poulan 2150 w/ walbro wt324 carb fuel line reassembly
the fule line that comes from the filter/ pick up will go straight to the nipple usualy the one closest to the middle of the carby.
the other hose comes from the carby to the in or **** side( punp it you can feel it)of the primer and then goes to the tank that is the return/ prime, nothing is conected to it in the tank. if you have the carby one the wrong way around it will not prime. just swap them over..
SOURCE: fuel line replacement
I recommend remove all fuel from the tank. Remove the hose from tank to carb. take the tube with you, when getting new hose.
SOURCE: I have a poulan pro 210 chainsaw both fuel lines
This should help:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
This too:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
Poulan.com
I think this is your saw please ensure I am correct.
http://www.ordertree.com/modelinfo/PWE/PP210-Gas-Saw/75.PP210-Gas-Saw.1.59.1.html
If not your saw it can be found here:
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. HTH
Lou
Take some pics first then a small sample of the different fuel lines to your local chainsaw seller. A little extra is agood idea, I have not found a good fuel line stretcher and I have been looking. Probably a good idea to replace the fuel filter too.
SOURCE: I have a walbro WT349 on a mac cat 38cc. chainsaw
Leave the hoses a little long an try it. Logic says the uppermost carburetor connection goes to the priver bulb, but you and I both know logic does not always work.
McCulloch IPLs (600160) You provide the prefix and suffix.
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
HTH
Lou
SOURCE: McCulloch,Mac 3200 Chainsaw fuel lines...........
retgmdI need the same, did you ever find one?
