20 Most Recent
Poulan Pro 14" Gas Chainsaw 33CC P3314 Questions & Answers
Sir, what is the starting adjustments on a Poluan 2000 Carb
Typical for any carburetor is 1 1/4 to 1 1/2 turns (out). These are just rough settings to get the saw running. Remove chain, turn idle throttle speed screw in to increase idle rpms so its less likely to stall. Follow mfg instructions for starting.
Once running, adjust low speed mix and allow a couple minutes to warm. Then re-adjust low speed and lower idle rpms by turning out idle throttle speed screw. Then with throttle wide open adjust high speed mix. If saw hesitates from idle to full throttle, open low speed mix 1/8 turn and readjust high speed mix.
If saw doesn't fire in 3 or 4 pulls remove plug. If plug is dry no fuel, if wet either no spark or idle mix to rich (or fuel metering may be fouled).
How to adjust bar oil for Poulan 3314
Sorry but there isn't an adjustment for the bar oil. You fill it up when you fill the mixed gas. Usually when you need gas you need oil too. Its a good idea to check the level and the bar. Wood chips can clog the oiler port and the tool will need to be disassembled, cleaned and checked.
Need fuel line routing for stihl fs36 trimmer
the line with the in-tank filter attached goes to the inlet side of the primer bulb
the action is from the tank through the pump into the needle area out to the primer back to the tank
Seems my Poulan Chainsaw P3314 is flooding.
Ron, the excessive gas could be the result of continued start attempts with a weak spark or a bad plug or a carboned plug. If none of the carb adjustments have not been turned or twisted prior, I'd suggest obtaining a fresh spark plug. Make sure the gap is correct. Blow out the cylinder with compressed air to vent all the residual gas/oil within. Ground the new plug against the engine and pull the cord. You should observe a fairly bright spark at the plug. If no spark you could have a faulty coil/ignition module. If a bright spark is present, install the plug and give it full choke and attempt to start. It should attempt to start within a few pulls....when it does, go immediately to HALF-choke and pull again and it should start.
P3314
Turn low side adjustment screw CCW a quarter turn.
