Meaning of the bios beep codes
The beep codes are BIOS specific and so you will need to pay attention to the post as your computer boots and note what BIOS it has. Then you can go to a website such as http://www.bioscentral.com/beepcodes/phoenixbeep.htm and look up the codes for your specific installation. On the right hand side you can select different types of BIOS.
SOURCE: Asus P5LP LE Emery motherboard MANUAL
does your case have set pin slot sets your case manual should tell how to install your motherboard type hope this helps
SOURCE: Asus P5LP-LE Motherboard Front Panel Pinouts
N/C Reset Gnd HDLED- HDLED+
GND PWR PWLED- PWLED+
SOURCE: Hello there! A while
I have spent over an hour on the Asus website looking for your motherboard and it is not listed in anyway. The Beeps at start up are really motherboard specific and only point you in a general area so you can pretty much ignore those for now. If you are sure you have the keyboard and you are using the on board Video try using a separate Video card. In most cases the board will allow you to install a different Video card but be careful that you are not installing a video card in the AGP slot and another card in teh top expansion slot. Asus has a bad habit of having those 2 slots share resources. When you put cards in both slots it causes a conflict and in most cases the Video will not work when that happens. If I could find a user manual on the motherboard it would be a lot of help but I am having no luck at all with finding information on your motherboard as you have it listed.
SOURCE: ASUS P4V800D-X AMI BIOS AMERICAN MEGATRENDS BEEP CODES
Hello here is some beep codes:
Beep CodeDescriptions 1 short
DRAM refresh failure 2 short
Parity circuit failure 3 short
Base 64K RAM failure 4 short
System timer failure 5 short
Process failure 6 short
Keyboard controller Gate A20 error 7 short
Virtual mode exception error 8 short
Display memory Read/Write test failure 9 short
ROM BIOS checksum failure 10 short
CMOS shutdown Read/Write error 11 short
Cache Memory error 1 long, 3 short
Conventional/Extended memory failure 1 long, 8 short
Display/Retrace test failed
My guess is you have a ram/memory module failure.
Try to renew the ram module.
The asus homepage is here:
http://support.asus.com/Download.aspx?SLanguage=en&m=p4v800d-x&p=1&os=
Here you can download a manual.
Please unzip the file when downloaded.
Your mainboard is using following type of ram:
Dual Channel Memory Architecture
4 x 184-pin DIMM Sockets support max. 4GB
PC3200/PC2700/PC2100 non-ECC DDR SDRAM memory.
These module does not exist bigger than 1GB.
