20 Most Recent
Intel S6240 Notebook Questions & Answers
I have a fujitsu lifebook
Are the beeps always the same pattern?
A motherboard BIOS can alert the user to potential problems by sending out an audio type of 'morse code'.
Each Bios has its own set of beep-codes, with unique meanings.
I have an old free app which may still be valid, called BIOS BEEP CODES.
This lookup database tells you what the beeps mean.
The BIOS is controlled by a chip / IC on the motherboard.
The codes are arranged in short and long pulses, eg
Award: 1 long + 3 short = whatever...
Also check when booting, usually bottom right, for Bios Ver.
Common Bios-chip manufacturers include AMI, AWARD, PHOENIX.....
My son has rotated the screen on my fujitsu lifebook s series so now it is upside down! How do i rotate it back? Please help!
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display. Windows XP/Vista Monitor Orientation Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
Num lock blinking
It might be an error code. Most laptops gives error codes in that way where the num lock blinks. Most common problem can be RAM related. Reseat the RAM and try again. If that doesn't work, RAM might be faulty or the RAM slot itself can be faulty. Try to google the error codes for your laptop and see specifically what error it might be.
Need OM Diagnostic Tool
I tend to agree with your thinking simply because of the reported sector error.I found this link claiming a Hitachi diagnostic tool will work on your Fujitsu, give it a whirl let me know:http://www.computing.net/answers/hardware/fujitsu-sata-diagnostics/59393.html
How can I activate the
On older laptops, there is sometimes a small toggle switch to turn wireless on. If not, there is a wireless icon on one of the F keys and you'll have to hold the Fn button and press that F key to turn it on. It's also good to have a wireless router so that once you do that, you can actually connect to something.
Cannot get laptop to find
Attempting to establish wireless or cable networking requires consulation with an expert. For example in the situation where prior devices establshed malfunctions requires to contact the host provider either as telenetworking, email, or location address where restore functionality is attained. Prior to contacting networking experts require ascertaining the details with devices either observation of malfunction with recorded model brands to attain restore functionalities.
When i switch on my lifebook , nothing happens and
remove the left side ram(most likely culprit) or the right side ram( if u have 2 ram modules installed) or swith the ram to the other slot if u only have one ram module installed and try to start/on the laptop again..pls feedback if it solved ur problem..TY
How to totally change the
I am assuming, that it is presently Japanese.
The only way to change all the languge is to install an English,(or other language),version of Windows.
You can replace the Japanese version, or add the English version as a second Windows.
The later will require double the memory space.
I forgot my password for
DOWNLOAD THE LOGIN IN SOFTWARE FROM WEBSITE AND BURN INTO CD AND BOOT WITH CD AND EASLY CHANGE THE ADMINISTRATOR PASSWORD ALSO
