I have a whirlpool electric range model number rf378pxg and both burners in the oven are not working. What would cause this?
There is a thermal fuse on the back of the oven that has probably popped (opened up). It looks kind of like a little top-hat tieh 2 terminals sticking out of it. On some models, this is resetable (it has a little red reset button in the center which you can press to reset), but in most models, it is not resetable, and you have to replace it.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
