NEC Electra Elite 32D-1 Corded Phone Logo
A
Anonymous Posted on Sep 07, 2014
How to conference call on a nec dtu 32d 1a phone?
SC Spike
Level 1:
New Friend:
  • Contributor 91 Answers
  • Posted on Sep 19, 2014
SC Spike
Contributor
Level 1:
New Friend:
Answers
91
Questions
0
Helped
31016
Points
98
When your're on a call, you press Conference, get internal dial tone, dial the extension you want or 9 plus the whole outside number you want, then press Conference again to tie the calls together. Some exts only have access to one call at a time, so if you can't make 2 calls at a time, this feature won't work.
1 Related Answer
Anonymous
  • 63 Answers
  • Posted on Mar 14, 2009
SOURCE: Programming speed dial numbers into NEC DTU-32D-1A phone
hit feature key,hit a line key,dial 9 plus the number,hit feature
Can NEC DTU-16D-1A be used with a standard PSTN line in?
Yes, the NEC DTU-16D-1A can be used with a standard PSTN line. You will need to program the phone system to recognize the PSTN line instead of the ISDN2 line. Here are some steps you can take:
  1. Access the programming mode on the NEC Xen Alpha system by pressing "Speaker" and then "7" on the main phone.
  2. Enter the system password, which should be provided in the user manual or by your system administrator.
  3. Press "Speaker" and then "3" to enter the line programming mode.
  4. Scroll through the line options using the arrow keys until you find the option for PSTN. Select this option.
  5. Save your changes by pressing "Speaker" and then "Store".
Once you have completed these steps, your NEC DTU-16D-1A handsets should be able to connect to the PSTN line and function properly.
Manual for DTU-32D-2
If you go online and type in your system type/user guide/PDF, some service companies have the user guide online for download.
1helpful
I bought a used nec electra elite DTU-32D phone system for the office. I would like to listen in on ongoing call for training purposes. How do I do that?
I'm showing your problem in the cell phone category but I guess we are talking about an office phone set up. There should be a way to just pick up the phone when another co-worker is doing a training call by pressing the button for the line he is using. If not then perhaps the manual suggests a way to set up a conference call.
Mar 19, 2011 • Cell Phones
4helpful
How do you turn the ringer off of an NEC-DTU-32D-2?
you need to remove ringing programming in 4-01 for that extension. ldtsnj.com
1helpful
Turn Volume Down
Yes while the phone is ringing use the down arrow key and it will lower the volume.
6helpful
Difficulty reading screen
As an FYI....The arrow keys control many things,
If not in use, they control the contrast.
If ringing, it adjusts ringing.
when using handset or speaker, it adjusts volume.
Nec phone DTU-32D
do you have VM on this system?
1helpful
2answers
NEC DTU-8D-1A TELEPHONE
Press Feature 1 That will turn the mic off, or on.
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
