My regular lights which use 12V transformer doesn't work properly. The transformer itself is good the lights are good two but they come ON and Off any time they want to. This is the reason I'm looking for LED lights 120V and trying to fix the problem this way. where can I find them? My stove is commercial thermador.
SOURCE: Light doesn't work on Kenmore Model 55022 Range hood...
If you're getting 120V at the lampholders, yet it's not lighting lamps that still work perfectly well in other fittings, two possibilitiesspring to mind.
One is that the cap on the bulbs isn't quite compatible with the fitting. Assuming they're some variant of Edison Screw, make sure that the centre terminal in the lampholder is sticking out far enough to touch the terminal on the bulb. Also check whether the lampholder achieves it's outer connection just with a small tab, rather than with the whole of the threaded ring. If so, make sure that this is going to touch the appropriate part of the bulb.
The other possibility is that you've got a high resistance connection somewhere - not enough of an open circuit to drop the 120 V when feeding the Megohm load presented by a meter, but more than enough to kill the supply when you have a lamp load. Only way to chase this is to use the meter on ohms range to bell out all the wiring between the lampholders and bits of the system which do work properly.
A.
SOURCE: my range stop working
Hi 7764,
I'm Harvey the Master Plumber.
Your problem is: You have monogram (df 8 08989 9) hood it all of a sudden stop working , there is power (120v) coming in ' but nothing works
If you have the testing equipment and the ability then check the fuse then the transformer then simply follow the power till you see where it stops. Or yu might try utilizing the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: INSTALLING NEW HOOD VENT RE CIRCULATING NO DUCT
The white which has the longer slot is the negative and the black wire which has the smaller slot is the positive ( hot ) wire.
SOURCE: Colour of the CDA CHIMNEY HOOD CPX7ss
the greyinsh blue color sounds like it still has the protective film on it that needs to be peeled off
SOURCE: I have a Euro-Kitchen 218 Series "Spagna Vetro"
DW, It is not the transformer. It could be the dimming controls. Also, instead of using a bigger transformer go in for CFL bulbs and reduce the load on the transformer. And contribute towards efforts to reduce global warming by using less electricity.
I have a similar issue. So far I have been unable to find a conversion light kit ....
