I think that it is an 1981 the system works like this for certain ones but where it was made makes a difference if it is made in U.S.A. this is how it is dated your # is 82681563= 1st&5th digit =81 2nd-4th= the day of the year=268=September 25th 56 = the production line # of guitars made till then 3= the 3rd guitar made on September 25th 1981 so the next guitar made after yours would be 574 and the # would read like this 82681574 but remember it matters where it was made in what country I hope this helped you
SOURCE: Gibson Les Paul wont stay in tune
clean out the slots with the stings use gibson vintage nickle wound 10s smooth notches on bridge dry graphite on nut slots lite oil on metal bridge 3 wraps on tuning posts hold 1st fret pull strings up to stretch and retune,do this a few times always set guitar on a stand to acclimate to, the temp at the gig ,you must spend the time to stretch out the strings. Jim 30 yr guitarist
SOURCE: I have a gibson les paul electric guitar and don't
Looks to be a 2003.
http://www.gibson.com/en-us/Support/SerialNumberSearch/
SOURCE: My Les Paul Guitar hums loudly but when I touch a
You have a grounding problem. Verify your cable is good first, then open the guitar and look for broken wires. The electronic parts sit in a cavity that SHOULD be lined with CONDUCTIVE paint that acts as a shield and should have an electrical connection. You will likely find ground wires soldered to the back of the control pot cases. If you find a wire broken loose you have found the cause. There is usually a wire to the ground system from the metal parts.
Testimonial: "Thank you. I will thoroughly check out the guitar using the information given."
