Cars & Trucks Logo
A
Anonymous Posted on Aug 17, 2014
How to change bulb
How do i change front headlight bulbs do i have to take the light out, this is on a bmw 318d
Neal marler
Level 1:
New Friend:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Aug 28, 2014
Neal marler
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
17
Questions
Helped
2584
Points
20
You can change the bulb from under the bonnet there should be a black rubber cover on the back of the light were the wires connect to the light bulb unplug light pull rubber cover remove metal clip then change bulb.
5 Related Answers
Anonymous
  • 1861 Answers
  • Posted on Oct 07, 2008
SOURCE: How to change front right headlight bulb (left side when facing car)
Unplug the connector running to the back of the headlamp bulb. Remove the rubber ring that is on the back of the headlamp. It just pulls off. After the rubber is removed, you will see the clip to release the bulb.
Anonymous
  • Posted on Dec 31, 2008
SOURCE: how do you change the right front headlight bulb on a kia sedona
Remove the headlight assembly. Just remove the 3 bolts with a 10 mm socket and pull it out so you can disconect the wire harness. After that pull the whole assembly out and unscrew the bulb cover. The bulb is held in with a spring clip.
Anonymous
  • 1214 Answers
  • Posted on Feb 03, 2009
SOURCE: bulbs keep burning out
When you replace headlights in today's cars, DO NOT TOUCH THE GLASS OF THE BULB!. Handle the bulb only with the packing material the bulb ships in, or with a clean dry cloth.The oils in your skin will cause premature failure of the bulb.
Also, check the sockets (car side) carefully to make sure they are not burned.
Anonymous
  • Posted on May 13, 2009
SOURCE: headlight bulb replacement
bulb, igniter, or module, in order of likelihood and cost.
My bulb was out, so had a bulb put in, but still out. Had an off-duty BMW tech do it.
HOWEVER, if you have the HID Xenon headlight option, you can get shocked to death (yes, death) if you touch the wrong things together.
It's in the owner's manual -- turn wheels in or out, on front inside of wheel well is a cover that has small screws holding it in. The there's a plastic cove that snaps off and, walla, you're at the back of the light. It just twists in and out.
Don't touch the new bulb (particularly if it's a Xenon).
I'd pay to get it done.
Anonymous
  • Posted on May 28, 2009
SOURCE: replace headlight bulb
Actually there are two little black tabs on top of each headlight housing and you simply have to pull them up to release the whole headlamp.
Then follow the rest of emissionwiz's solution.
It's a 2002 bmw 745i dash sayinsaying licence light malfunction front headlight malfunction left turn signal malfunction what's the problem
Change the license tag light bulb.
Change the left turn signal light bulb.
Change the headlight bulb.
2answers
How do I replace front HID light bulb? and where can I purchase parts for replacing?
  1. INSTALLATION GUIDE:
  2. BMW E38 99-01 HID TYPE 7 Series 1PC Halo Amber Projector Headlights
  3. Parts Identification:
  4. Projector Headlight
  5. Halo & L.E.D.
  6. Bottom of the Headlight:
  7. Ballast Bracket, Halo Wires(red/black)
  8. Turn Signal Adaptor
  9. TOOLS REQUIRE
  10. 10mm - 8mm socket
  11. Philip Screwdriver
  12. Crimper/Pliers
  13. For more information about how to install your vehicle, come visit our youtube page on
  14. http://www.youtube.com/spyderauto
  15. Remove the facotry headlight from the BMW. First remove the front panel cover below the headlight to access the bottom screw of the headlight housing. There is also two screws on the top of the housing.
  16. Once you have remove the headlight, turn the headlight around and remove the bracket that holds the Ballast. Then remove the ballast using a philip screwdriver.
  17. Unplug the wire from the ballast, and then remove the Xenon Plug from the housing. Put the Ballast aside.
  18. Carefully remove the D2S Xenon Bulb from the factory housing. Once you have remove the bulb, transfer the bulb to the Spyder headlights.
  19. Remove the bracket from the Spyder Headlight, and then install the ballast on the housing like the original. Once you have put the ballast on, put the bracket back on.
  20. Remove the Panel Cover bracket from the original headlight to the new Spyder Headlights as shown here.
  21. STEP:
  22. Install the Spyder turn signal socket if the orignal does not fit, unplug the factory plug from the harness and plug the new one on.
  23. Install the Spyder Headlight back on to the vehicle. Plug the Harness back on, the halo/L.E.D. Wires is connect to the Parking lights. These wires are optional to your vehicle, you do not have to wire them together.
  24. Factory Xenon Headlight
  25. Spyder Projector Headlight using Factory Xenon Lights
1helpful
2answers
How to change headlight bulb
On the back of the headlight where the wires enter, you should be able to twist and remove the lamp holder. Be careful with the new bulb if it is halogen, do not touch the bulb!!
2answers
How do I get to the front headlight to change it
Re: Replace headlight bulb
  5. Halo & L.E.D.
  9. TOOLS REQUIRE
  12. Crimper/Pliers
  21. STEP:
  26. STEP:
BMW e46 HID Headlight Replace
2answers
How do i reset the run flat warning light on my bmw 318d 2007
dealer only diagnostic equipment ,or take the bulb out
4helpful
2answers
How do you change front headlight blub 2008 sonata
how do you change front headlight blub 2008 sonata
How to change a marker light bulb
to change the turn signal bulb on the headlight there is usually either a screw or tab that releases parking light lense from headlight. to just completely remove the headlight there are the two screws up top and also two lower if we are taking about the right side(drivers side, standing in front of vehicle) one of the screw is to the right side down near the inner fender, it is even with the bottom of the headlight. the other screw can be seen between the headlight and the radiator support about in the same area just opposite the other side. take a flashlight with you, not too hard to see
1helpful
2003 bmw headlight bulb
BMW2003 530I how to change front trun signal bulb
5helpful
Changing headlamps on 2003 bmw 325xi
I am assuming that you have a burned out head light bulb.
1) Open hood.
2) Working in back of headlight assembly, grasp rear of bulb socket (harness connector) and turn counterclockwise 90 degrees. Pull bulb out of headlight assembly.
3) Disconnect harness connector from bulb (gently pry, it's plastic)
4) Installation is reverse of removal. (Do not touch halogen bulb with bare skin-oils from hand will cause bulb to burn out.) Align tabs on bulb base to cutouts on rear of lens assembly. (Note bottom tab is wider than other two) Secure bulb by rotating clockwise 90 degrees.
Low beam bulb H9006
High beam bulb H9005
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
