1.From your Optimum Voice phone line, dial *86.2.Follow the simple steps to set up your voicemail password, create your greeting, and confirm your service choices.
Voice mail is usually set on first button (number one) of dialer and when you press it for long time you get an message to set the voice mail number if not set earlier or by default. Just ask your provider for voice mail number and put it when requested.
hi, if you can't use your voice mail, maybe you can use your answering machine in your jet itself...
just configure your answering machine to simply answer all your phone calls, if you are busy.. it will record all callers messages...
it is actually the alternative for your voice mail..
to switch on your voice mail, if you prefer to use the network service. you may try the following steps..
1. press settings..
2. on your settings, select applications
3. on your applications, select all calls
4. on your all call settings, select your voice mail and input your voice mail service number..
5. once finished, select save, and exit your settings menu..
6. to check if it's working.. use another phone to call your number, but be reminded that if your built in answering machine is on, turn if off..
good luck..
Access the main menu of your Samsung Go Phone. Hold the #1 key down until you are connected to the voice mail system. If for some reason pressing the #1 key doesn't connect you to voice mail then call customer service at 1-800-331-0500. You will be connected with an operator who can help you troubleshoot the voice mail problems on your Go Phone.
2 Follow the voice prompts and select "Listen to Messages" from the list of options. Bear in mind that checking voice mail on a Samsung Go Phone will count against your prepaid minutes.
3 Once you have finished you can select the "Delete Message" option from the voice prompt if you wish to clear your voice mail messages. If not, you can simply press "clear" or hang up the phone to leave the voice mail system.
If an Engineer has previously set up a Mail Box on your Voice Mail, then you need to assign a VMMSG button to that extension. this will allow access to your Voice Mail. I have posted a Voice Mail training video for you to watch- if you need the key setting up, go to youtube and search 'abbeytel' look for the 'how to program a softkey', I hope this helps, written help is available at
Setting Up Your Voice Mail from page 10 in your manual: Voice mail allows callers to leave voice messages, which can be retrieved any time.
Note: Once your voice mail account has been set up, you can use the Voice Mail folder (under the Message menu) to view details of voice messages in your voice mail box.
1. In idle mode, press and hold the key or dial your own mobile number to dial voice mail.
2. Follow the prompts in the new user tutorial to setup your mail box.
Listen to voice mail 1. In idle mode, press and hold the key or dial your own mobile number to dial voice mail. After connecting, you will hear your voice greeting. 2. Interrupt your greeting by pressing . 3. You are then prompted to enter your password.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time. JimmyC
