Kitchen Appliances - Others Logo
A
Anonymous Posted on Aug 13, 2014
Which regulator must I use for my imperial fryer .
Treefrog15
Level 2:
Habit-Forming:
  • Expert 130 Answers
  • Posted on Sep 23, 2014
Treefrog15
Expert
Level 2:
Habit-Forming:
Answers
130
Questions
0
Helped
79888
Points
224
Maxitrol RV48 series for most applications, 0.5psi natural gas.
1 Related Answer
Anonymous
  • 612 Answers
  • Posted on Oct 19, 2009
SOURCE: imperial gas fryer problem, when the burners are
You have a bad gas valve. It's not reading the signal from the thermostat. The gas valve is stuck open.
Does this unit require a pressure regulator
This unit should not require a regulator unless your gas pressure is more than 14" water column or 1/2 psi. In most applications this unit will not require an additional regulator as it uses a combination gas valve/regulator.
Flame not going into heat tubes
Make sure the regulator assembly on the gas valve is for propane. Sounds like the gas pressure is too low and the flames aren't going into the burner tubes. Make sure they didn't install an appliance regulator on the back of the fryer. This is not needed as the fryer has a regulator on the gas valve. You can unscrew the cap on the regulator assembly and turn the plastic screw inside all the way in. DO not turn with alot of force. Easy does it.
Tom
Hi,i want to know wath is the oil's temperature when the deep fryer is off and if a can regulate the pilot? my deep fryer is a imperial fsi-50,thanks
I would guess about 120-150F for the oil. There is a screw under a cap on the gas valve that you can use to regulate the pilot, but this is not recommended. The flame must be high enough to heat the thermopile sufficiently so that the pilot will stay on and the main valve actuate. For better or worse, most gas fryers are designed to keep solid shortning in a liquid state when off and to safely melt it overnight. If you need the oiler cooler, say for filtering, I suggest just turning off the pilot.
Fryer coming on without turning thermostat on
Imperial Model: IFS-40.
The thermostat is either very far out of calibration or has failed, either case it should be relplaced. The Imperial Part # for the thermostat is 1175.
Want to change natural gas to propane
You need to change the regulator,gas valve and burner orfices and possibly the pilot.If you have a commercial fryer go to 3wire.com and you will find the part's you need.Any questions?
Blew out the gas valve because they sold me the wrong regulator
Goto 3wire.com,type your model in.Before you try to fire it up i strongly suggest you check the gas pressure on the gas line or you will blow the valve again.
Fryer pilot lit but main burner does not come on
IT IS A GAS PRESSURE PROBLEM CHECK TO SEE IF THERE IS A GAS REGULATOR IN LINE WITH THE GAS PIPE TO THE FRYER IF SO ADJUST REGULATOR TAKE TOP ALUMINUM SCREW OF YOU WILL SEE WHITE PLASTIC SCREW TURN WHITE SCREWW TO THE RIGHT ALL THE WAY IF SAME PROBLEM OR NO REGULATOR RESTICTION IN GAS LINE
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
