Washing Machines Logo
A
Anonymous Posted on Aug 13, 2014
MY LSE7806ACE STACKABLE WASHER/DRYER UNIT IS 15 YRS OLD AND NEVER ONE PROBLEM. WAHER QUIT. REPAIRMAN REPLACED TIMER. WORKED 1 WEEK. REPAIRMAN REPLACEDFUSE. WORKED 1 WEEK REPAIRMAN REPLACED WATER INLET
UNIT IS 15 YRS OLD AND NEVER ONE PROBLEM. WASHER QUIT. REPAIRMAN REPLACED TIMER.WORKED ONE WEEK. REPAIRMAN REPLACED FUSE, WORKED ONE WEEK. REPAIRMANTRIED NEW FUSE AND WOULD NOT WORK SO HE REPLACED WATER INLET VALVE UNIT. WRKED FOR 4 WEEKS AND BEGAN BLOWING FUSES. AT PURHASE WE WERE TOLD THE GUIDE AT THE RIGHT BACK OF THE WASHER MUST CONNECT INTO A SOCKET ON THE LEG OF THE DRYER WHEN YOU PUSH THE WASHER UNDER THE DRYER. I DID NOTICE THAT THE GUIDE PIN WAS BENT.
Tim Hofstetter
Level 3:
Genius:
  • Master 1,406 Answers
  • Posted on Aug 13, 2014
Tim Hofstetter
Master
Level 3:
Genius:
Answers
1406
Questions
0
Helped
378967
Points
4295
If it's 15 years old, it doesn't owe you very much.
5 Related Answers
A
Anonymous
  • Posted on Jul 11, 2008
SOURCE: Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Anonymous
  • 784 Answers
  • Posted on Aug 03, 2008
SOURCE: washer will not spin
The spin pulley is made by plastic. It worn overtime becoming shorter then original shape. When the thickness of pulley is short, it won't be able to engage the clutch inside the transmission to make the drum spin. The spin pulley is not expensive. I read an article about a gentlement replacing a transmission, the brake assembly plus the new belt could not make it spin. I carefully examined the whole thing by turning the belt in the direction of spinning and saw the transmission slipped. That was why I figured out. Transmission has 2 ways of turning: one is for agitation, and the other is for spinning. The pulley has to turn inorder to compress the brake assembly to free from friction and at the same time to engage the clutch so the drum will spin.
Anonymous
  • 686 Answers
  • Posted on Apr 06, 2009
SOURCE: Maytag LSE7806ACE dryer stopped working
pry the top up at the corners and remove attaching screws for the front panel and remove carefully. Now you should be able to see the canister that contains the heat element and the thermal fuse. If your thermal fuse is bad you also need to replace the high limit thermostat switch which is located on the canister itself and check that the heating element is not broken anywhere throughout the coil.
Anonymous
  • 3361 Answers
  • Posted on May 20, 2009
SOURCE: Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
Mike Inman
  • 219 Answers
  • Posted on May 22, 2009
SOURCE: washer won"t fill with water
check your lid switch if its a top load
1helpful
1helpful
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Washer won't drain or spin
YOU MIGHT BROKE THE DOOR SWITCH CHEC IT OUT FIRST... IT CAN BE BYPASS IF YOU WANT :) LET ME KNOW
2answers
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
2helpful
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
2answers
2helpful
6answers
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Top Washing Machines Experts
john h
