Behringer EUROPOWER EP4000 4,000-Watt Stereo Power Amplifier with ATR Logo
A
Anonymous Posted on Aug 10, 2014
How do you hook up tascam 500 cd player to behringer 4000 amp ?
Carl Grunwald
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Nov 26, 2014
Carl Grunwald
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
1305
Points
11
You will need some type of preamp like a mixer
PMP 4000. Porneste sursa putin iar apoi dispare tensiunea de alimentare a amplificatoarelor
That appears to be Italian in our English speaking website
PMP 4000. Start the source a little and then the supply voltage of the amplifiers disappears
https://translate.google.ca/?hl=en&tab=TT&sl=auto&tl=en&text=PMP%204000.%20Porneste%20sursa%20putin%20iar%20apoi%20dispare%20tensiunea%20de%20alimentare%20a%20amplificatoarelor&op=translate
Only Behringer can fix
Service - Behringer
www.behringer.com > service
SHOULD THE SOFTWARE PROVE DEFECTIVE, YOU ASSUME THE ENTIRE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
and
https://www.behringer.com/product.html?modelCode=P0A8N
How to hook up my Behringer V-amp pro
Hook it up to what? You'll probably want it in the insert on the guitar channel.
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
1helpful
We have a pmp6000 mixer hooked up to our ep 4000 and b1800 and b2520,it seems we can only hook up the amp to the mixer into either mono's 1 and 2 or the main 2 however not in main 1 with full...
MAKE SURE the cables you plug into 1/4 inch mains are TRS plugs, and not mono cables (TS). The main output 1/4 inch jacks are TRS balanced outputs and if you plug mono (TS) cables that shorts out the ring connector reducing the power by 6 Db. USE ONLY TRS balanced cables for interconnects !!!! Also read my tip on Fixya regarding PMP mixers. If you use 1/4 inch SPEAKER cables or adapters, if you short the SLEEVE of channel A output to ground you can pop the channel A amp. The TIP of channel B is the hot BUT the SLEEVE of channel A is the HOT. The ttip I posted explains why this is and it isn't mention in the Behringer documentation.
I need instalation diagram for tascam DR-1 to behringer 2442
We don't have any graphic means of diagramming. You also don't say if this is for recording or playing or both. Assuming it is both, your best way would be to get two 1/8 stereo cables that split into two RCA plugs. Go from the headphone out of the DR1 to the CD inout jacks on the mixer. Then with the second cable go from teh CD out jacks of the mixer to the line in of the DR1.
I have a Tascam US1641 USB interface and wanted to know if you can connect a Behringer 2442fx to it to use it as a mixdown control for my music in Cubase studio5.
The 2442FX has a built in usb interface so there is really no need to use the Tascam. Here is a link for you:http://www.behringer.nl/EN/Products/2442FX.aspx
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
