Generator wont start
Have you solved the problems? If you haven't, maybe the following reasons will be helpful for you.
After using a diesel generator for a long time, some malfunctions may occur that will cause the generator fail to start.
If diesel generators fail to start, you can analyze the causes from fuel system failure, electric starting system failure, insufficient compression pressure in the cylinder and the low ambient temperature and other factors.
1. Air in the fuel system
2. Fuel Line Obstruction
3. Fuel Filter Clogging
4. The Handle Position of Fuel Injection Pump Is Not Correct
5. Battery Power Shortage
6. Battery Power Shortage
To know more reasons, here is article that will be helpful. Why Diesel Generator Fail to Start
If you want to know more information about generator, visit this website: http://www.dieselgeneratortech.com
Check for spark. If it has spark, try starting using starting fluid. If that starts it, then you know it is a fuel problem. You may need to rebuild the carb.
