Craftsman 17.5hp* Shift-on-the-Go 42" Lawn Tractor CA Only Logo
A
Anonymous Posted on Aug 05, 2014
Craftsman service manuals
Oil leaking from exhaust box at front of engine . Lots of smoke ? Why. ?!
Eugene Rounds
Level 3:
  • Craftsman Master 1,169 Answers
  • Posted on Aug 05, 2014
 Eugene Rounds
Craftsman Master
Level 3:
Answers
1169
Questions
Helped
592968
Points
4432
If oil is leaking from the muffler most like you engine is overfilled.
HIgher than normal level can be cause a leaking carburetor filling the crankcase with gas.
If it leaking from the valve cover then it needs resealing.
5 Related Answers
Anonymous
  • 146 Answers
  • Posted on Jun 07, 2010
SOURCE: Oil leak on riding Craftsman LT2000 (Kohler)
Fortunately, the engine oil doesn't go through any rubber hoses, so they are mouse-proof. The oil probably leaked out through an engine seal. Oil on the engine surfaces would smoke when it gets hot. Check your oil level and top it up if necessary, before you run the engine again. The engine can run fine even with a slow oil leak; you just have to watch the oil level from time to time. The leak could be easy to fix - by tightening up a few bolts -- or expensive.
The gas runs through rubber hoses, though. If mice ate through that, I think you would have smelled the gasoline, and the engine wouldn't run for more than a few seconds. But if you see a severed hose, you should replace it. Take it off and bring it to a mower shop or auto supply shop, and buy something the same diameter. Inexpensive.
Hope this helped! If so, please rate my answer, thanks!
Testimonial: "Whew, you've eased my mind. I'll head out tomorrow and try your suggestions. I really appreciate your input and the fact that you are willing to respond! Thank you!"
Anonymous
  • 5 Answers
  • Posted on Aug 01, 2010
SOURCE: oil dripping from front of
Put a new gasket on the valve cover ort tighten the bolts on the current.
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Sep 17, 2010
SOURCE: I have a LT1000 19.5 HP Craftsman engine that
Hi and welcome to FixYa. I am Kelly. Your oil rings are most likely stuck against the piston skirt. This can happen if the engine overheats or the engine oil is not being changed at the recommended intervals.
There is a couple of ways to try and free them up without an engine tear down. The first way is to use a 30W detergent oil vs a 30 SAE oil. Drain the engine and add detergent oil. after 5 to 10 hours of use do it again. The go back to regular 30W SAE oil. Detergent oil will make the aluminum crankcase appear internally polished if it is working / cleaning things up.
The second way is to over drain the oil and then fill the engine up as best you can i.e over-servicing big time with engine flush. Make sure an OLD spark plug is installed. Turn it thru a few times by hand and let it sit over night. Next day drain engine flush service with DETERGENT oil for at least a 5 hour operating interval and then change oil back to 30W SAE oil. If your in a hot environment it is recommended that you always use Detergent oil.
Pennzoil HD30 = detergent oil (Example only) Use any brand 30W detergent oil.
If the above does not lessen the oil blow by then the only option at that point would be to change the piston rings / inspect cylinder bore wear. I would not give up on this engine. B & S parts are available for your engine.
I have brought a lot of engines back to life by simply doing rapid interval detergent oil changes.
A few others took the engine flush soaking to get them to snap out of it... Of course there are some that have over-heated so badly there is no hope other than parts changes. I don't think your engine is to that point yet.
Just an note... if you need help with parts info I will need your ENGINE model number that is on stamped on the air shroud and or the block data plate.
Thanks for choosing FixYa.
Kelly
#1 Taper
Jim Parker
  • 1041 Answers
  • Posted on Sep 24, 2010
SOURCE: I have a 20hp,Craftman lawn tractor, single
If you keep running it in this condition, it will eventually seize up on you. You are going to need to rebuild the motor. Oil is getting by the ring on the piston. And gas is getting into the crankcase because it's being mixed with oil and not burning properly.
My advice would be to stop using it and get it fixed, before you cause even more damage.
Good Luck!
Jim
Anonymous
  • 4 Answers
  • Posted on May 14, 2012
SOURCE: I Have a craftsman ys4500 tractor 42in deck, 21
You may want to check the choke cable to see if its working properly.
I keep adding engine oil on my 2006 BMW 530i, engine has no leaking. Any help?
Check exhaust smoke color when engine hot. If there is white smoke, there may be oil in the pipes. Means the valve seal is leaking oil into the cylinder. Another way to check is to look at the spark plug tips. If is full of soot like burnt oil then the oil is leaking into the cylinders.
If yours is E60 turbo, check the presence of residue oil in both the exhaust and intake turbine. If there is, the oil seals in the turbo housing is leaking oil. They do sell service kits for turbos.
I have a 1988 Scottsdale 305 4x4 manual trans.its leaking oil so bad smoke rolls from under the hood when I come to a stop.i know the exhaust it lose but could it be just that?
Yup, oil is leaking directly onto the exhaust and burning. Fix the oil leaks, normally always the valve cover gaskets, and replace the pcv valve(PCV positive crankcase ventilation valve). See can you put another PCV valve in the other valve cover and run it to the breather. The more of these lines you hook between the engine and breather, the less it will leak because vacuum is pulling all the pressure out of the engine block and crankcase so it won't push the oil out. My 383 small block has a bad front main seal, I hooked up another tube and it can't push oil out the seal. No more leaks. Hope you get her fixed soon Bro, you really look bad with all that smoke coming from your truck.
1helpful
Engine oil consumtion is one liter per week, what the problem
Hi Joey:
We'll need to trouble shoot this.
The oil could be:
- burning because of bad rings (lots of blue smoke from exhaust)
- burning because of bad PVC valve (lots of oil in intake system)
- Leaking from a bad seal or gasket (lots of oil on underside of engine
It never hurts to do a really good cleanup on the engine and then run it for a very short time. Then check for the ource of the leak
1helpful
2answers
Oil going out from level gearbox
what gear box.
5speed manual "GL4 gear lube 4, can stink bad"
or autotmatic. (ATF pink fluid, and smells sweet)
what engine, some engines, leak oil and goes to the bell housing
then down hill (gravity and wind) to the exh. pipes.
what engine, the 2.7L V6? or G16 or J20? what?
and on calif cars they have calif exhuast, and fits up different,..
so no country stated, or if in calif. (exhaust questions....)
if the gear box leaks, (any)
we first check to see if its overfilled (Jiphphyboobs/syndrome)
if M/t the side plug inspection port, and transfer case.
if A/T box. (automatic) we read the operators guide, not guessing how and read that on a hot running engine we check ATF levels.
if overfilled the ATF foams and will leak and cause bearing failure.
air bubbles do not work right as lubrication... ever.
filled to hot mark on dip stick
unless the stick is missing, as is true on newer cars.
if trans leaks, say where it leaks.
top , bottom
front or rear.??
pretend we are blind. and win.
2answers
Why is my 2000 kia sephia blowing blue smoke from the tailpipe. it has 86,000 miles. the check oil warning light is on even though the dipstick reads full.
The most common cause of blue exhaust smoke is oil leaking past engine seals and into the cylinders where it then mixes and burns with the fuel. This is most frequently seen in older or high mileage cars with worn seals and gaskets. It only requires a very small amount of oil leaking into the cylinders to cause excessive blue exhaust smoke.
Blue exhaust smoke only at start-up can indicate worn piston seals or damaged or worn valve guides which may also cause a rattling noise. An external engine oil leak can drip onto hot engine and exhaust parts causing what appears to be blue exhaust smoke. Other possible causes of blue exhaust smoke include: piston wear, worn valve seals, a dirty or non-functioning PCV valve, worn piston rings, an intake manifold gasket leak, worn engine oil seals and possibly even head gasket failure.
Oil leaking into the cylinders can cause a rough idle, misfire and fouled spark plugs. In addition, a reduction in power and oil loss can be indicators that the blue exhaust smoke is caused by an internal engine oil leak. Internal engine oil leaks can also allow fuel to mix with the oil in the crankcase which will degrade the oil and prevent it from adequately protecting the engine.
Operating a car with a severely dirty oil filter, air filter or improperly functioning PCV valve can also sometimes result in engine oil blow-by, oil loss and blue exhaust smoke. Periodically checking the engine oil level with the oil dip stick will indicate if there is excessive oil consumption. Higher viscosity engine oil can sometimes temporarily reduce the amount of blow-by; however, this is not generally recommended. Excessive blue exhaust smoke indicates a possible internal engine oil leak that should be inspected by an ASE certified mechanic.
Oil leaking on exhaust manifold and smoking on 1998 nissan altima 2.4
You need to find out just were the oil is leaking from to start with .I have just done my Mercedes with the same problem valve cover gasket was leaking .Oil was leaking down the side and on the plugs that are hot ,, so it burns off the oil ,this is what you can smell. If other items are doing the same you will need to do that part as well..The breather system may be blocked up also if it is not breathing oil will build up . Good luck
White smoke billowing from front of mower
is the smoke from the exhaust?or just the front of the engine look for a oil leak from the head gasket
Apr 30, 2012 • Garden
I have a ford xe 351v8 it blows lots of black smoke
Black smoke tells me your piston rings are worn. Also the fumes you have explained tells me the valve seals are worn and leaking oil as well
The leaking valve seals and pistion rings will expell the fumes out through the exhaust. If you check your oil level every 50 miles and the oil level is down a half quart or more serious engine wear has occured and needs to be rebuilt soon
Smoke and oil coming out of the front exhaust of
chech engine oil level ,if oil level its up carburetor flout neddl valve leak and the fuel run into engine
Aug 22, 2009 • Garden
5helpful
Hard starting smokes white like gas is getting into cylinders
White smoke in a small engine is oil. Oil in the cylinder will create too much pressure for the engine to achieve compression. Make sure the engine is not getting fuel into the oil and thinning the mixture (literally smell the oil... gasoline and oil smell nothing alike, if it smells like gas, it is). If this is the case, the carb is leaking fuel into the engine, thinning the oil and causing the oil to leak past the rings into the cylinder head, through the valves and, from there, into the exhaust to burn off. Black smoke indicates a direct fuel issue in a small engine, white is oil based.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
