SOURCE: LG dryer DLE 3733S control panel inop but light on
Check the power to the display panel after you have it removed. If there is no power check the lines to the control, If the power is present with no action on the panel then you will have to replace the board. It may be as simple as cleaning the board off, since it has been a intermittent problem in the past. hopes this helps Tim
Hello & Welcome to FixYa
If you have already cleaned the vent then the
problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be
reset and replacing it is recommended repair. It is located on the blower wheel
housing inside the rear panel to the exhaust duct. You can test it for
continuity before replacing. Please get back to me if you have any other
questions.
Kevin
