its is simple on the desktop click right button of the mouse and select new and then click on it
you can create your own folder.pls visit the following site
HP LaserJet MFP and All-in-One Products - HP Universal Print Driver: Bin ... and LaserJet AiO/product Products - Solve Common Macintosh problems 25 Mar 2011 ... h20000.www2.hp.com/.../SupportTaskIndex.jsp?... - Cached - SimilarHP LaserJet M4345 Multifunction Printer series - Manuals - HP ...HP LaserJet M4345 MFP - (multiple language) Getting Started Guide North ... h20000.www2.hp.com/.../SupportTaskIndex.jsp?... - Cached - Similar
A 59.4 error is a failure of the main cartridge drive motor. Sometimes this can be triggered by a cartridge that does not turn freely. Try turning the machine off and leave it for about five minutes and then turn back on. If that does not work, replace the cartridge and try again. If that does not cure it then the motor will need to be replaced, assuming that no one has been monkeying around inside the printer because we sometimes get this error if motor connector is left off.
[email protected]
To perform a cold reset 1 Turn the MFP off and then on. 2 When the memory count appears on the control-panel display, press and hold 6 until all three LEDs flash once and then stay on. This might take up to 20 seconds. 3 Press 3 four times until COLD RESET appears on the control-panel display. 4 Press 6 one time. The MFP continues its initialization sequence.
