I am facing this problem with a Proliant DL380 G4 server .
Occassionally it starts rebooting frequently . When this problem occurs the server reboots before it enters the OS repeatatively . The problem frequency is nearly once in 15 days. Then if we just change the SMPS slot, or say open one fan then boot ( it gives error ) , then again fix the fan ,the server starts up normally . The problem again occurs after 15 to 20 days . Can you please suggest a permanent solution. Is there any problem in the bios ?
Same as above. IT takes reboot fits. The last time 8/20/07 I took all parts out and put them back in and it was OK until now.Same as above. IT takes reboot fits. The last time 8/20/07 I took all parts out and put them back in and it was OK until now.
You can't post conmments that contain an email address.
Please first make sure that you are using the proper startup boot disk for the server before entering the CD ROM option from the boot menu. Also, check the front panel of the SCSI drives for any errors or blinking LEDS that correspond to an error code. You can run a diagnostics CD/DVD that arrived with the manufacturer's pack to detect any raid issues on startup.
If you are still facing difficulties with booting up the server, you can find a video for replacement of the appropriate scsi drive here if you are still facing any issues of your scsi drive. Try a different hard disk or check the relevant diagnostics to verify whether is the controller or the drive that complicates the booting of the server
Assuming the system is powering on but you can't see the POST, reset the jumpers on the board for POST (Check your user manual for location), reboot your system, which should go into the POST, make any correction needed, reset the jumper and reboot your system.
need to provide moreinfo. is the server (prolaint DL380) constantly rebooting within BIOS mode or has it got to the stage of running windows.
The other item not mentioned here, is, IF the raid controller has failed, you will not see any disks initializing and would cause the system to continually reboot. If it is an internal raid controller, it is part of the motherboard, you will need to contact HP to have it replaced.
If an pci related array controller .. i.e. separate to the motherboard, this will need to be replaced to see the HDD's.
Either way sounds like a hardware issue.
Best to liaise directly with vendor to have the faulty components replaced.
Make sure you have turned on the USB Boot in the BIOS of the os. Once this is done, select the order you would like for the server to locate boot files. (Hard Drive, USB, CD/DVD, etc.) Once complete, insert the USB and reboot the server.
Hi, Disable the ASR auto-reboot
feature from System Management web page. open a case at HP, and run the diagnostic tools from smartstart CD. Kindly let me know.
Is your server under carePAQ/ support by HP.
Please go to the System Settings/BIOS of the server by pressing F9 while booting. Check for error messages.
Please check for the processor support matrix also. You may want to try upgrading the motherborad firmware berfore loading this proc.
