MagLite Mag-Lite& Flashlight Logo
A
Anonymous Posted on Jul 30, 2014
How to replace a light in a mag lite old police style flashlight?
2 Related Answers
Anonymous
  • Posted on Oct 03, 2008
SOURCE: Mag lite
I have a regular AA Mag light that had industrial strength batteries which corroded.I did get them out but the bulb holder on the light broke.(The main bulb holder where the twist on switch is.)
Anonymous
  • 79 Answers
  • Posted on Sep 23, 2011
SOURCE: reassemble 2 aa mag lite. I rook mag lite apart
There shouldn't be one. Getting it out of there was probably the best thing for it.
How do I replace the led in a 2w d cell maglite
Unscrew the top half of the flash light and pull the bulb straight up, and it's out,
Not to mention there's usually a spare bulb in the base of the flashlight under the spring in a piece of foam. unless someone used it already,
Line up the two pins and slide it back into the to pin holes on top and with the bottom of the flashlight back on with battery's try the on off switch and make sure it lights up and not have dead battery's, if it lights up throw away the old led and screw on the top of flashlight,
If it still don't light check for new battery's.
The part that is inside the flashlight that the bulb plugs into, can you buy just that part?
I have tried to buy that same part for years and years and am told by the Maglite* company that it is not replaceable. ( so I have a box of about 5 old lites that are of no use :-( ).
sorry,
c...
Couldn't find out how to take bulb part out so I could get corroded batteries out
The back of a Mag-lite screws off to replace the batteries. Look for textured lines like on a coin.
1helpful
MAG-Lite flashlite with Battery removal problem
Pull the cap off the end and wack it in your hand or a piece of wood, don't swing it like a baseball bat. Sometimes they get stuck in mine also, Not sure why, but a good wack gets the job done. Don't worry, the flashlight can take it.
2helpful
Mag lite
Top MagLite Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a MagLite Electrical Supply Expert? Answer questions, earn points and help others
