20 Most Recent MagLite Mag-Lite& Flashlight Questions & Answers
0answers
0answers
0answers
CORROWDED BATTERIE STUCK IN FLASHLITE
Put on a pair of gloves. Then, using needle nose pliers grasp the battery and pull it out. If it's too far down to reach with needle nose, or if the corrosion has "welded" it to the inside of the flashlight, find a flat head screwdriver or stiff wire coat hanger or other tool/object that will reach and is stiff enough to pry the offending battery loose. Once it's broken free, turn it upside down and let the battery fall out on its own. The important thing now is, if you plan on using the flashlight again, cleaning out the inside thoroughly of all corrosive residue. This is particularly important on the metal battery/power contacts. A wire brush should suffice for the inside of the flashlight. Sand paper or file will work for the contacts. Attach to the tip of a screwdriver if you need to reach deep to get them clean. Baking soda will neutralize the battery acid. Finally, remember to recycle the offending battery not throw it out with the regular garbage.
12/13/2013 2:36:00 AM • MagLite... • Answered on Dec 13, 2013
0answers
2answers
Mini Maglite AA A
yes u can just be careful in removing it
7/23/2013 8:42:30 PM • MagLite... • Answered on Jul 23, 2013
2answers
Battery case does not open
make sures its being turned to the left, and if it will not come off, wrap duct tape around it to protect it and use large vice grips or pliers to get it off. Vice grips would be better as the lock but dont' lock them down too tight as you can dent the cap.
3/15/2013 1:56:33 PM • MagLite... • Answered on Mar 15, 2013
My 6d maglite keeps blowing the bulb
6D Maglite? As in 6 D cell batteries? 1-1/2 Volts (Each battery), times 6 = 9 Volts.Using the proper bulb?The original is a Krypton bulb. (No, I didn't make the name up)http://www.toolup.com/maglite_lmsa601_mag-num-star-6d-relacement-bulb.aspxhttp://www.batteryjunction.com/maglite6c.htmlGuess what happens if you put a 3 Volt bulb with 9 Volts?Regards,joecoolvette
11/27/2012 8:57:01 AM • MagLite... • Answered on Nov 27, 2012
2answers
I can't remove the end of my mini maglite to
unscrew the rear piece to change batterys.
7/29/2012 8:40:39 AM • MagLite... • Answered on Jul 29, 2012
3answers
I have a mini Maglite with one battery stuck in the barrell
I had a similar problem. My wife put two AA rechargeable batteries into her mini maglite. Apparently the AA rechargeables have a slightly larger diameter than alkaline batteries. One of them was stuck in the barrel. I was able to remove it by first removing the lens and bulb so as not to break it. Then I slammed slamming the barrel down hard onto the carpet on our floor. This hard shock jarred the battery loose and it came out of the barrel. Hope this helps someone out.
10/28/2011 12:08:30 AM • MagLite... • Answered on Oct 28, 2011
My maglite recharable three battery light will not
Best thing to do is send in for warranty repair if the battery an bulb is OK. I would replace the bulb first to verify that it is OK. If it does not work then go to:http://www.maglite.com/repaircenters.aspand find the nearest repair center. Gary
10/17/2011 8:28:27 PM • MagLite... • Answered on Oct 17, 2011
3 D mag flashlight diagram
Parts diagram is at: http://maglitesales.com/maglitestore/index.php/cPath/12_13Gary
10/17/2011 8:24:34 PM • MagLite... • Answered on Oct 17, 2011
My husband has lost a piece from inside the
Yes you can buy parts. Google parts or go to: http://maglitesales.com/maglitestore/index.php/cPath/12_13Good luck, Gary
10/17/2011 8:03:53 PM • MagLite... • Answered on Oct 17, 2011
I cannot get the cap
Probably a leaking battery has coroded the cap. You can send it direct to MagLite for warranty. Go to: http://www.maglite.com/repaircenters.asp to find the nearest warranty/repair center. Gary
10/17/2011 8:02:12 PM • MagLite... • Answered on Oct 17, 2011
Mini Maglite end, where batteries
You can send it direct to MagLite for warranty/repairGo to: http://www.maglite.com/repaircenters.asp to find the nearest warranty/repair center. Gary
10/17/2011 8:00:58 PM • MagLite... • Answered on Oct 17, 2011
My 3 d mag-lite does not respond to the switch
You can send it direct to MagLite for warranty. Go to: http://www.maglite.com/repaircenters.aspto find the nearest warranty/repair center. Gary
10/17/2011 7:59:34 PM • MagLite... • Answered on Oct 17, 2011
MagLite Mag-Lite& Flashlight Logo
81 questions posted
Top MagLite Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a MagLite Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • MagLite Electrical Supplies
Most Popular Question
mini maglite aa
  • Electrical Supplies
