The video may be failing. Backup any important data. Then, try to make sure you have the latest drivers. See this... https://www.youtube.com/watch?v=-i1wWtdEmcY
and this... https://www.youtube.com/watch?v=pdVFKFLRQXg
Just search on Youtube for "Lenovo ideapad shaky screen"
SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
SOURCE: Lenovo IdeaPad Y530 - 40512SU screen is dark
Have you installed the Lenovo EnergyCut drivers? Without it, laptop may not work properly and turns extra hot. Try letting it cool down before you try again.
SOURCE: Lenovo Ideapad- screen has begun
The screen control board coudl be goign bad. The heatsheild in the screen could be the cause. The cable that sends the signals to the screen could be bad. The graphic chip could be overheating or could be starting to detatch from the motherboard.This is not something you should look at yourself. It is best to be taken to a technician.
SOURCE: I am looking for lenovo
Hi 284607,
I see you need assistance on replacing the LCD screen on your Lenovo Y510 Laptop.
I have a link here that you can got do and download the information on how to replace the LCD screen on your Lenovo Y510 machine but then again just a disclaimer, any damages that may occur during the replacement Lenovo will not be held Liable.
See link for the Details:
LCD replacement Y510
I hope that this helps.
Have a nice day,
mvincentc
SOURCE: Lenovo Yoga Touch screen Quad core tablet has no sound
Check the MUTE setting has not been set on the speakers.
Check the Volume setting, move to a higher volume level.
Try re-installing the Audio driver.
