20 Most Recent
Lenovo Yoga IdeaPad Ultrabook 13.3" Touch-Screen Laptop - 4GB Memory - Silver Questions & Answers
How to reset power on password
What happened to you is a good reason not to set this password. Unfortunately there is no user-serviceable way for you to reset this password. See the Password section in the hardware manual on page 24. The suggestion is that you will need to have the system board replaced at your own expense.
http://download.lenovo.com/consumer/mobiles_pub/ideapad_yoga13_hmm_1st_edition_oct_2012_english.pdf
There may be other options open to you including opening your IdeaPad and removing the CMOS battery or using BIOS cracking software if you are able to boot to a CD or USB device. These options may not be feasible to you as they are particularly technical in nature so you may need to find a qualified technician to perform this work if it is even possible. Good luck.
HOW TO EJECT A DISC IN LENOVO IDEAPAD 330
The CD/DVD drive may be opened by pressing a button on the drive itself. If the drive does not open by pressing a button on the drive itself, or the button is not available on the drive, Windows natively provides the ability to eject the tray with simple methods that can be performed in the File Explorer. The steps vary from different operating systems:
Note:
- Not all systems come with a CD-ROM, CD-RW, or DVD drive installed internally to the computer
- To verify that, you can check the left and right side of your machine. See if there is any slot to insert your CD/DVD. Normally, there is a button to eject the CD or DVD tray for you to insert a disc
- Another method to identify this is as below:
1. Click Start and type Device Manager in the search box. Select Device Manager
2. In Device Manager look for DVD/CD -ROM Drives
If you don"t see DVD/CD -ROM Drives this means your device has no optical drive hardware. An external optical drive will need to be purchased to run CD/DVD. It is also wise to check your product specification to see if your device has an optical drive.
If you were previously able to play CD/DVD and DVD/CD -ROM Drives has disappeared from device manager or your device is not reading the disc please follow > Your CD or DVD drive is not recognized by Windows or other programs.
- The format capabilities of the drive are listed on the label on the external cover of the drive
- The CD-ROM, CD-RW, or DVD drive can be opened using the emergency eject hole (Bend away a leg of a paperclip to work with. Insert the paperclip slowly until there is resistance, then gently push until the drive door is opened) Applicable Brands
Solution
·Windows 10
·Windows 7 Eject disk tray with File Explorer
- Turn off all applications currently using the drive. Otherwise Windows will prevent you from ejecting the DVD tray
- Hold Windows + E on the keyboard to open File Explorer
- Click the DVD drive icon and click the "Eject" button on the toolbar or right-click on the optical drive and choose Eject from the menu that pops up or down.
Win 10 lenvo ideapad 320 will not play mygames now
really why not ask the game maker directly for help with your w10.
here they are right>?
https://www.mygames.com/
so what do THEY say , it is there code, running.
does Tetris fail or just your games, unnamed,
this maker is bad company they take over your PC
why run this crappp? it takes over your browser,
and more,
and is bad.
the do not even have minimum system requirement there.
nor support. avoid like the Plague.
