Worked fine. older flip phone. put it on charger overnight and it went dead? Tryed another charger and still nothing?
SOURCE: Razr v3 dead battery
you have a dead battery, this happens often. all you can do is just buy one, ebay
SOURCE: phone wont turn on
Battery is so low it won't turn on. Leave on charger for a half hour or so and it will turn on again. Replacing the battery worked for me!
SOURCE: fone dead
yeah wokka i had the same problem.what you do is...turn your phone on so it go's to that white screen take the cover off the back and take the battery out while the phone is on,thus cutting the power then plug into charger with the battery out,it took me a bit of stuffing around to get it to work.so just keep taking the battery out then after a few times put the battery back in the phone and plug the charger in without turning the phone on.if the little screen on the front lights up with the "charging sign"then switch the phone on and it should work. if not keep trying.dont know how or why this works but it worked for mine...which was good because these phones take such a great photo only thing that lets them down is that dodgy swivel camera which stuffs up after a while.hope this helps tho....
SOURCE: phone will not turn on unless it's plugged in
The battery has a short in it and if you replace it The phone should probubly work.
SOURCE: my phone wont charge
I have the same phone and bought a new charger and it still wont work, it's the phone
